MINI MXQ RK3229 4K TV BOX 1G/8G 4K 10bit H.265/H.264 Smart Media Player
    Android 4.4
    Rockchip RK3229 quad core Cortex-A7 Up to 1.5GHz
    Mali-400MP; OpenGL ES 2.0
    1GB DDRIII & 8GB Samsung eMMC
    IEEE 802.11 b/g/n 2.4G WiFi
    HDMI 2.0 for 4K@60Hz with HDCP 1.4/2.2
    4K 10bit H.265/H.264 video decoder
    Model MINI MXQ
    Quantity 1 Piece
    Color Black
    Operating System Android 4.4
    CPU RK3229, quad core Cortex-A7 Up to 1.5GHz
    GPU GPU Mali-400MP
    OpenGL ES 2.0
    RAM 1GB
    ROM 8GB EMMC
    Extended Storage TF CARD Support 1~32GB
    Wifi Connectivity IEEE 802.11 b/g/n 2.4G WiFi
    Ethernet 10/100 BaseT
    Bluetooth Yes
    Video Supported Video Decoder:4K VP9 Video decoder, 4K 10-bits H.265/H.264 Video decoder, 1080P other video decoders (VC-1, MPEG-1/2/4, VP6/8)
    Video Encode:1080P video encoder for H.264 and VP8
    Audio Supported Audio Container:supports MP3 / AAC / WMA / RM / FLAC / OGG and programmable with 5.1 down-mixing
    Audio Ou:HDMI/SPDIF Data Output
    Picture Supported HD JPEG/BMP/GIF/PNG/TIFF
    Resolution 4K*2K
    Language Chinese , English ,Germany ,Japanese, Korea etc. 24 languages
    HDMI Port HDMI 2.0 for 4K@60Hz with HDCP 1.4/2.2
    1*Power Button
    1*DC in Port
    2*Standard USB Port
    1*HDMI A Type Port
    1*RJ45 (100Mbps network connection)
    1*S/SPDIF (2CH, 5.1CH)
    1*Micro SD card slot
    1*Power LED with two - color
    Power DC5V 2A(100-240V,50/60Hz)
    Package Contents
    1 x TV box
    1 x IR remote
    1 x HDMI cable
    1 x Power adapter (A right AC Adapter will be sent as your shipping country)
    1 x User manual
    great box!
      Originally posted by Gecycreat
      great box!
      Why?
      Sent from my GT-I9190 using Tapatalk
        Originally posted by Damac10 View Post
        Why?
        I like the super thin box.
          I like the Orange it's the new black incase you did not know...
            I got mine already and nothing great about box. 2 fast ota updates and display start green after loading logo. Now box can't be turned on by button and become peace of crap.I hope its same red light fault like Beelink X2 ,but don't know did someone will make firmware to fix this.Still waiting answer from shop till now this chipset and maker with be out of my shopping list .May be its faulty unit it's new product ,but till now i cant find manufacturer page to try upgrade firmware.If someone know please post it here
              Please some one to make backup of stock rom and post me a link. My device is still bricked and i found the way to recover it via micro sd card,but can't find any rom
                I just bought 2 of these boxes (love the size) got 21226 point in Antu Benchmark, 3GB free storage on the 8GB, "is there an lollipop update or are we stuck on kitkat forever."
                Also is it normal that the remote control cannot turn the box ON, it will shut it down but not turn it ON.
                How do i use the drop down menu with the remote control, I select mouse mode move the pointer over the drop down area then press ok and down arrow but it does not work.
                EDIT: Also i don't appear to have Bluetooth on my MINI MXQ box. ???
                John.
                  Yes, it is normal for that model.
                    In this model there is no Bluetooth. You need to attentively read model specs before you buy.
                    You can explore packing box of that model, you will not find any "Bluetooth" word on it.
                    On this page is written "Bluetooth: Yes" but it is wrong.
                      What else is there to know about this box? I got it, it works well, the remote is okay but I'm gona be ordering a keyboard/trackpad combo anyway. Some apps don't support scrolling with a remote which sucks. I hate Kodi being preinstalled so I installed Jarvis.
                      Twitch.tv streams on 1080 do not play smoothly.
                      What about updates? Firmwares?
                      Does anyone know how to play games on this thing?
                        I asked for an android 5 firmware on Amazon, and was given this link, Is it for our Mini MXQ RK3229 1GB 8GB
                        I have not flashed a TV box before, Could somebody check the file out?
                        John.
