A10 chipset CKK PAD MID-008a Need firmware..
You may have flashed a ROM that erased the EEPROM to control the screen. Rockchip never has this problem because they do not do this. But A10 EASILY can do this! In fact this is a common problem!
Even if you get the stock ROM, your screen may not work because the stock ROM does not flash the screen EEPROM!
See my post here about all this. I made the same mistake and spent a long time learning to recover it.
http://www.freaktab.com/showthread.p...X-touch-screen!
Originally posted by Finless View PostYou may have flashed a ROM that erased the EEPROM to control the screen. Rockchip never has this problem because they do not do this. But A10 EASILY can do this! In fact this is a common problem!
can you help me sir to fix my tablet? what should i do first?
i flash these firware i am using livesuite and sucessfully done but my problem i dont know how to fix the touch screen can you give me a firmware?
[IMG][/IMG]
this is the script.bin dump in my tablet sir can you check it for me..?
[product]
version = "1.0"
machine = "A10-EVB-V1.2"
[target]
power_start = 0
boot_clock = 1008
dcdc2_vol = 1400
dcdc3_vol = 1250
ldo2_vol = 3000
ldo3_vol = 2800
ldo4_vol = 2800
pll4_freq = 960
pll6_freq = 960
storage_type = 0
[card_boot]
logical_start = 40960
sprite_gpio0 =
[card_boot0_para]
card_ctrl = 0
card_high_speed = 1
card_line = 4
sdc_d1 = port:PF0<2><1><default><default>
sdc_d0 = port:PF1<2><1><default><default>
sdc_clk = port:PF2<2><1><default><default>
sdc_cmd = port:PF3<2><1><default><default>
sdc_d3 = port:PF4<2><1><default><default>
sdc_d2 = port:PF5<2><1><default><default>
[card_boot2_para]
card_ctrl = 2
card_high_speed = 1
card_line = 4
sdc_cmd = port:PC6<3><1><default><default>
sdc_clk = port:PC7<3><1><default><default>
sdc_d0 = port:PC8<3><1><default><default>
sdc_d1 = port:PC9<3><1><default><default>
sdc_d2 = port:PC10<3><1><default><default>
sdc_d3 = port:PC11<3><1><default><default>
[twi_para]
twi_port = 0
twi_scl = port:PB0<2><default><default><default>
twi_sda = port:PB1<2><default><default><default>
[uart_para]
uart_debug_port = 0
uart_debug_tx = port:PB22<2><1><default><default>
uart_debug_rx = port:PB23<2><1><default><default>
[jtag_para]
jtag_enable = 0
jtag_ms = port:PB14<3><default><default><default>
jtag_ck = port:PB15<3><default><default><default>
jtag_do = port:PB16<3><default><default><default>
jtag_di = port:PB17<3><default><default><default>
[dram_para]
dram_baseaddr = 0x40000000
dram_clk = 408
dram_type = 3
dram_rank_num =
dram_chip_density =
dram_io_width =
dram_bus_width =
dram_cas = 6
dram_zq = 123
dram_odt_en = 0
dram_size =
dram_tpr0 = 0x30926692
dram_tpr1 = 4240
dram_tpr2 = 0x1a0c8
dram_tpr3 = 0
dram_tpr4 = 0
dram_tpr5 = 0
dram_emr1 = 4
dram_emr2 = 0
dram_emr3 = 0
[mali_para]
mali_used = 1
mali_clkdiv = 3
[g2d_para]
g2d_used = 1
g2d_size = 0x1000000
[emac_para]
emac_used = 0
emac_rxd3 = port:PA0<2><default><default><default>
emac_rxd2 = port:PA1<2><default><default><default>
emac_rxd1 = port:PA2<2><default><default><default>
emac_rxd0 = port:PA3<2><default><default><default>
emac_txd3 = port:PA4<2><default><default><default>
emac_txd2 = port:PA5<2><default><default><default>
emac_txd1 = port:PA6<2><default><default><default>
emac_txd0 = port:PA7<2><default><default><default>
emac_rxclk = port:PA8<2><default><default><default>
emac_rxerr = port:PA9<2><default><default><default>
emac_rxdV = port:PA10<2><default><default><default>
emac_mdc = port:PA11<2><default><default><default>
emac_mdio = port:PA12<2><default><default><default>
emac_txen = port:PA13<2><default><default><default>
emac_txclk = port:PA14<2><default><default><default>
emac_crs = port:PA15<2><default><default><default>
emac_col = port:PA16<2><default><default><default>
emac_reset = port:PA17<1><default><default><default>
[twi0_para]
twi0_used = 1
twi0_scl = port:PB0<2><default><default><default>
twi0_sda = port:PB1<2><default><default><default>
[twi1_para]
twi1_used = 1
twi1_scl = port:PB18<2><default><default><default>
twi1_sda = port:PB19<2><default><default><default>
[twi2_para]
twi2_used = 1
twi2_scl = port:PB20<2><default><default><default>
twi2_sda = port:PB21<2><default><default><default>
[uart_para0]
uart_used = 1
uart_port = 0
uart_type = 2
uart_tx = port:PB22<2><1><default><default>
uart_rx = port:PB23<2><1><default><default>
[uart_para1]
uart_used = 0
uart_port = 1
uart_type = 8
uart_tx = port:PA10<4><1><default><default>
uart_rx = port:PA11<4><1><default><default>
uart_rts = port:PA12<4><1><default><default>
uart_cts = port:PA13<4><1><default><default>
uart_dtr = port:PA14<4><1><default><default>
uart_dsr = port:PA15<4><1><default><default>
uart_dcd = port:PA16<4><1><default><default>
uart_ring = port:PA17<4><1><default><default>
[uart_para2]
uart_used = 1
uart_port = 2
uart_type = 4
uart_tx = port:PI18<3><1><default><default>
uart_rx = port:PI19<3><1><default><default>
uart_rts = port:PI16<3><1><default><default>
uart_cts = port:PI17<3><1><default><default>
[uart_para3]
uart_used = 0
uart_port = 3
uart_type = 4
uart_tx = port:PH0<4><1><default><default>
uart_rx = port:PH1<4><1><default><default>
uart_rts = port:PH2<4><1><default><default>
uart_cts = port:PH3<4><1><default><default>
[uart_para4]
uart_used = 0
uart_port = 4
uart_type = 2
uart_tx = port:PH4<4><1><default><default>
uart_rx = port:PH5<4><1><default><default>
[uart_para5]
uart_used = 0
uart_port = 5
uart_type = 2
uart_tx = port:PH6<4><1><default><default>
uart_rx = port:PH7<4><1><default><default>
[uart_para6]
uart_used = 0
uart_port = 6
uart_type = 2
uart_tx = port:PA12<4><1><default><default>
uart_rx = port:PA13<4><1><default><default>
[uart_para7]
uart_used = 0
uart_port = 7
uart_type = 2
uart_tx = port:PA14<4><1><default><default>
uart_rx = port:PA15<4><1><default><default>
[spi0_para]
spi_used = 0
spi_cs0 = port:PI10<3><default><default><default>
spi_cs1 = port:PI14<3><default><default><default>
spi_sclk = port:PI11<3><default><default><default>
spi_mosi = port:PI12<3><default><default><default>
spi_miso = port:PI13<3><default><default><default>
[spi1_para]
spi_used = 0
spi_cs0 = port:PA0<4><default><default><default>
spi_cs1 = port:PA4<4><default><default><default>
spi_sclk = port:PI1<4><default><default><default>
spi_mosi = port:PI2<4><default><default><default>
spi_miso = port:PI3<4><default><default><default>
[spi2_para]
spi_used = 0
spi_cs0 = port:PC19<3><default><default><default>
spi_cs1 =
spi_sclk = port:PC20<3><default><default><default>
spi_mosi = port:PC21<3><default><default><default>
spi_miso = port:PC22<3><default><default><default>
[spi3_para]
spi_used = 0
spi_cs0 = port:PA5<4><default><default><default>
spi_cs1 = port:PA9<4><default><default><default>
spi_sclk = port:PI6<4><default><default><default>
spi_mosi = port:PI7<4><default><default><default>
spi_miso = port:PI8<4><default><default><default>
[rtp_para]
rtp_used = 0
rtp_screen_size = 7
rtp_regidity_level = 7
rtp_press_threshold_enable = 0
rtp_press_threshold = 8000
rtp_sensitive_level = 15
rtp_exchange_x_y_flag = 0
[ctp_para]
ctp_boxchip_type = 2576
ctp_used = 1
ctp_twi_id = 2
ctp_name = "ft5x_ts"
ctp_twi_addr = 0x38
ctp1_used = 1
ctp1_name = "Goodix-TS"
ctp1_twi_addr = 0x55
ctp2_used = 0
ctp2_name = "ssd253x-ts"
ctp2_twi_addr = 0x48
ctp2_ssd_type = 0x111d5
ctp3_used = 1
ctp3_name = "novatek-ts"
ctp3_twi_addr = 0x9
ctp4_used = 1
ctp4_name = "zet622x-ts"
ctp4_twi_addr = 0x76
ctp5_used = 1
ctp5_name = "byd693x-ts"
ctp5_twi_addr = 0x52
cpt_screen_rotate = 0
ctp_screen_max_x = 800
ctp_screen_max_y = 600
ctp_revert_x_flag = 0
ctp_revert_y_flag = 0
ctp_exchange_x_y_flag = 0
ctp_havekey = 1
ctp_int_port = port:PH21<6><default><default><default>
ctp_wakeup = port:PB13<1><default><default><1>
ctp_io_port = port:PH21<0><default><default><default>
[tkey_para]
tkey_used = 0
tkey_name = "hv_keypad"
tkey_twi_id = 2
tkey_twi_addr = 0x62
tkey_int = port:PI13<6><default><default><default>
[motor_para]
motor_used = 0
motor_shake = port:PB3<1><default><default><1>
[nand_para]
nand_used = 1
nand_we = port:PC0<2><default><default><default>
nand_ale = port:PC1<2><default><default><default>
nand_cle = port:PC2<2><default><default><default>
nand_ce1 = port:PC3<2><default><default><default>
nand_ce0 = port:PC4<2><default><default><default>
nand_nre = port:PC5<2><default><default><default>
nand_rb0 = port:PC6<2><default><default><default>
nand_rb1 = port:PC7<2><default><default><default>
nand_d0 = port:PC8<2><default><default><default>
nand_d1 = port:PC9<2><default><default><default>
nand_d2 = port:PC10<2><default><default><default>
nand_d3 = port:PC11<2><default><default><default>
nand_d4 = port:PC12<2><default><default><default>
nand_d5 = port:PC13<2><default><default><default>
nand_d6 = port:PC14<2><default><default><default>
nand_d7 = port:PC15<2><default><default><default>
nand_wp = port:PC16<2><default><default><default>
nand_ce2 = port:PC17<2><default><default><default>
nand_ce3 = port:PC18<2><default><default><default>
nand_ce4 =
nand_ce5 =
nand_ce6 =
nand_ce7 =
nand_spi = port:PC23<3><default><default><default>
nand_ndqs = port:PC24<2><default><default><default>
[disp_init]
disp_init_enable = 1
disp_mode = 0
screen0_output_type = 1
screen0_output_mode = 4
screen1_output_type = 1
screen1_output_mode = 4
fb0_framebuffer_num = 2
fb0_format = 10
fb0_pixel_sequence = 0
fb0_scaler_mode_enable = 0
fb1_framebuffer_num = 2
fb1_format = 10
fb1_pixel_sequence = 0
fb1_scaler_mode_enable = 0
[lcd0_para]
lcd_used = 1
lcd_pwm_not_used = 0
lcd_pwm_ch = 0
lcd_pwm_freq = 10000
lcd_pwm_pol = 1
lcd_x = 800
lcd_y = 600
lcd_dclk_freq = 40
lcd_if = 0
lcd_hbp = 46
lcd_ht = 1056
lcd_vbp = 23
lcd_vt = 1270
lcd_hv_if = 0
lcd_hv_smode = 0
lcd_hv_s888_if = 0
lcd_hv_syuv_if = 0
lcd_hv_vspw = 0
lcd_hv_hspw = 0
lcd_lvds_ch = 0
lcd_lvds_mode = 0
lcd_lvds_bitwidth = 0
lcd_lvds_io_cross = 0
lcd_cpu_if = 0
lcd_frm = 0
lcd_io_cfg0 = 0x10000000
lcd_gamma_correction_en = 0
lcd_gamma_tbl_0 = 0
lcd_gamma_tbl_1 = 0x10101
lcd_gamma_tbl_255 = 0xffffff
lcd_bl_en_used = 1
lcd_bl_en = port:PH7<1><0><default><1>
lcd_power_used = 1
lcd_power = port:PH8<1><0><default><1>
lcd_pwm_used = 1
lcd_pwm = port:PB2<2><0><default><default>
lcd_gpio_0 =
lcd_gpio_1 =
lcd_gpio_2 =
lcd_gpio_3 =
lcdd0 = port:PD0<2><0><default><default>
lcdd1 = port:PD1<2><0><default><default>
lcdd2 = port:PD2<2><0><default><default>
lcdd3 = port:PD3<2><0><default><default>
lcdd4 = port:PD4<2><0><default><default>
lcdd5 = port:PD5<2><0><default><default>
lcdd6 = port:PD6<2><0><default><default>
lcdd7 = port:PD7<2><0><default><default>
lcdd8 = port:PD8<2><0><default><default>
lcdd9 = port:PD9<2><0><default><default>
lcdd10 = port:PD10<2><0><default><default>
lcdd11 = port:PD11<2><0><default><default>
lcdd12 = port:PD12<2><0><default><default>
lcdd13 = port:PD13<2><0><default><default>
lcdd14 = port:PD14<2><0><default><default>
lcdd15 = port:PD15<2><0><default><default>
lcdd16 = port:PD16<2><0><default><default>
lcdd17 = port:PD17<2><0><default><default>
lcdd18 = port:PD18<2><0><default><default>
lcdd19 = port:PD19<2><0><default><default>
lcdd20 = port:PD20<2><0><default><default>
lcdd21 = port:PD21<2><0><default><default>
lcdd22 = port:PD22<2><0><default><default>
lcdd23 = port:PD23<2><0><default><default>
lcdclk = port:PD24<2><0><default><default>
lcdde = port:PD25<2><0><default><default>
lcdhsync = port:PD26<2><0><default><default>
lcdvsync = port:PD27<2><0><default><default>
[lcd1_para]
lcd_used = 0
lcd_x = 0
lcd_y = 0
lcd_dclk_freq = 0
lcd_pwm_ch = 1
lcd_pwm_freq = 0
lcd_pwm_pol = 0
lcd_if = 0
lcd_hbp = 0
lcd_ht = 0
lcd_vbp = 0
lcd_vt = 0
lcd_hv_if = 0
lcd_hv_smode = 0
lcd_hv_s888_if = 0
lcd_hv_syuv_if = 0
lcd_hv_vspw = 0
lcd_hv_hspw = 0
lcd_lvds_ch = 0
lcd_lvds_mode = 0
lcd_cpu_if = 0
lcd_frm = 0
lcd_io_cfg0 = 0
lcd_gamma_tbl_0 = 0
lcd_bl_en_used = 0
lcd_bl_en =
lcd_power_used = 0
lcd_power =
lcd_pwm_used = 1
lcd_pwm = port:PI3<2><0><default><default>
lcd_gpio_0 =
lcd_gpio_1 =
lcd_gpio_2 =
lcd_gpio_3 =
lcdd0 = port:PH0<2><0><default><default>
lcdd1 = port:PH1<2><0><default><default>
lcdd2 = port:PH2<2><0><default><default>
lcdd3 = port:PH3<2><0><default><default>
lcdd4 = port:PH4<2><0><default><default>
lcdd5 = port:PH5<2><0><default><default>
lcdd6 = port:PH6<2><0><default><default>
lcdd7 = port:PH7<2><0><default><default>
lcdd8 = port:PH8<2><0><default><default>
lcdd9 = port:PH9<2><0><default><default>
lcdd10 = port:PH10<2><0><default><default>
lcdd11 = port:PH11<2><0><default><default>
lcdd12 = port:PH12<2><0><default><default>
lcdd13 = port:PH13<2><0><default><default>
lcdd14 = port:PH14<2><0><default><default>
lcdd15 = port:PH15<2><0><default><default>
lcdd16 = port:PH16<2><0><default><default>
lcdd17 = port:PH17<2><0><default><default>
lcdd18 = port:PH18<2><0><default><default>
lcdd19 = port:PH19<2><0><default><default>
lcdd20 = port:PH20<2><0><default><default>
lcdd21 = port:PH21<2><0><default><default>
lcdd22 = port:PH22<2><0><default><default>
lcdd23 = port:PH23<2><0><default><default>
lcdclk = port:PH24<2><0><default><default>
lcdde = port:PH25<2><0><default><default>
lcdhsync = port:PH26<2><0><default><default>
lcdvsync = port:PH27<2><0><default><default>
[tv_out_dac_para]
dac_used = 1
dac0_src = 4
dac1_src = 5
dac2_src = 6
dac3_src = 0
[csi0_para]
csi_used = 1
csi_mode = 0
csi_dev_qty = 1
csi_stby_mode = 1
csi_mname = "gc0308"
csi_twi_id = 1
csi_twi_addr = 0x42
csi_if = 0
csi_vflip = 0
csi_hflip = 0
csi_iovdd = ""
csi_avdd = ""
csi_dvdd = ""
csi_flash_pol = 1
csi_mname_b = "gt2005"
csi_twi_id_b = 1
csi_twi_addr_b = 0x78
csi_if_b = 0
csi_vflip_b = 0
csi_hflip_b = 0
csi_iovdd_b = ""
csi_avdd_b = ""
csi_dvdd_b = ""
csi_flash_pol_b = 1
csi_pck = port:PE0<3><default><default><default>
csi_ck = port:PE1<3><default><default><default>
csi_hsync = port:PE2<3><default><default><default>
csi_vsync = port:PE3<3><default><default><default>
csi_d0 = port:PE4<3><default><default><default>
csi_d1 = port:PE5<3><default><default><default>
csi_d2 = port:PE6<3><default><default><default>
csi_d3 = port:PE7<3><default><default><default>
csi_d4 = port:PE8<3><default><default><default>
csi_d5 = port:PE9<3><default><default><default>
csi_d6 = port:PE10<3><default><default><default>
csi_d7 = port:PE11<3><default><default><default>
csi_d8 =
csi_d9 =
csi_d10 =
csi_d11 =
csi_d12 =
csi_d13 =
csi_d14 =
csi_d15 =
csi_reset = port:PH13<1><default><default><0>
csi_power_en = port:PH16<1><default><default><0>
csi_stby = port:PH18<1><default><default><0>
csi_flash =
csi_af_en =
csi_reset_b = port:PH13<1><default><default><0>
csi_power_en_b = port:PH16<1><default><default><0>
csi_stby_b = port:PH19<1><default><default><0>
csi_flash_b =
csi_af_en_b =
[csi1_para]
csi_used = 0
csi_mode = 0
csi_dev_qty = 1
csi_stby_mode = 1
csi_mname = ""
csi_twi_id = 1
csi_twi_addr = 0xba
csi_if = 0
csi_vflip = 0
csi_hflip = 0
csi_iovdd = ""
csi_avdd = ""
csi_dvdd = ""
csi_flash_pol = 1
csi_mname_b = ""
csi_twi_id_b = 1
csi_if_b = 0
csi_vflip_b = 1
csi_hflip_b = 0
csi_iovdd_b = ""
csi_avdd_b = ""
csi_dvdd_b = ""
csi_flash_pol_b = 1
csi_pck = port:PG0<3><default><default><default>
csi_ck = port:PG1<3><default><default><default>
csi_hsync = port:PG2<3><default><default><default>
csi_vsync = port:PG3<3><default><default><default>
csi_field =
csi_d0 = port:PG4<3><default><default><default>
csi_d1 = port:PG5<3><default><default><default>
csi_d2 = port:PG6<3><default><default><default>
csi_d3 = port:PG7<3><default><default><default>
csi_d4 = port:PG8<3><default><default><default>
csi_d5 = port:PG9<3><default><default><default>
csi_d6 = port:PG10<3><default><default><default>
csi_d7 = port:PG11<3><default><default><default>
csi_d8 =
csi_d9 =
csi_d10 =
csi_d11 =
csi_d12 =
csi_d13 =
csi_d14 =
csi_d15 =
csi_d16 =
csi_d17 =
csi_d18 =
csi_d19 =
csi_d20 =
csi_d21 =
csi_d22 =
csi_d23 =
csi_reset = port:PH14<1><default><default><0>
csi_power_en =
csi_stby = port:PH17<1><default><default><0>
csi_flash =
csi_af_en =
csi_reset_b =
csi_power_en_b =
csi_stby_b =
csi_flash_b =
csi_af_en_b =
[tvout_para]
tvout_used = 0
tvout_channel_num = 1
tv_en = port:PI12<1><default><default><0>
[tvin_para]
tvin_used = 0
tvin_channel_num = 4
[sata_para]
sata_used = 0
sata_power_en =
[mmc0_para]
sdc_used = 1
sdc_detmode = 1
bus_width = 4
sdc_d1 = port:PF0<2><1><2><default>
sdc_d0 = port:PF1<2><1><2><default>
sdc_clk = port:PF2<2><1><2><default>
sdc_cmd = port:PF3<2><1><2><default>
sdc_d3 = port:PF4<2><1><2><default>
sdc_d2 = port:PF5<2><1><2><default>
sdc_det = port:PH1<0><1><default><default>
sdc_use_wp = 0
sdc_wp =
[mmc1_para]
sdc_used = 0
sdc_detmode = 1
bus_width = 4
sdc_cmd = port:PH22<5><1><2><default>
sdc_clk = port:PH23<5><1><2><default>
sdc_d0 = port:PH24<5><1><2><default>
sdc_d1 = port:PH25<5><1><2><default>
sdc_d2 = port:PH26<5><1><2><default>
sdc_d3 = port:PH27<5><1><2><default>
sdc_det = port:PH2<0><1><default><default>
sdc_use_wp = 0
sdc_wp =
[mmc2_para]
sdc_used = 0
[mmc3_para]
sdc_used = 0
sdc_detmode = 1
bus_width = 4
sdc_cmd = port:PI4<2><1><2><default>
sdc_clk = port:PI5<2><1><2><default>
sdc_d0 = port:PI6<2><1><2><default>
sdc_d1 = port:PI7<2><1><2><default>
sdc_d2 = port:PI8<2><1><2><default>
sdc_d3 = port:PI9<2><1><2><default>
sdc_det =
sdc_use_wp = 0
sdc_wp =
[ms_para]
ms_used = 0
ms_bs = port:PH6<5><default><default><default>
ms_clk = port:PH7<5><default><default><default>
ms_d0 = port:PH8<5><default><default><default>
ms_d1 = port:PH9<5><default><default><default>
ms_d2 = port:PH10<5><default><default><default>
ms_d3 = port:PH11<5><default><default><default>
ms_det =
[smc_para]
smc_used = 0
smc_rst = port:PH13<5><default><default><default>
smc_vppen = port:PH14<5><default><default><default>
smc_vppp = port:PH15<5><default><default><default>
smc_det = port:PH16<5><default><default><default>
smc_vccen = port:PH17<5><default><default><default>
smc_sck = port:PH18<5><default><default><default>
smc_sda = port:PH19<5><default><default><default>
[ps2_0_para]
ps2_used = 0
ps2_scl = port:PI20<2><1><default><default>
ps2_sda = port:PI21<2><1><default><default>
[ps2_1_para]
ps2_used = 0
ps2_scl = port:PI14<3><1><default><default>
ps2_sda = port:PI15<3><1><default><default>
[can_para]
can_used = 0
can_tx = port:PA16<3><default><default><default>
can_rx = port:PA17<3><default><default><default>
[keypad_para]
kp_used = 0
kp_in_size = 8
kp_out_size = 8
kp_in0 = port:PH8<4><1><default><default>
kp_in1 = port:PH9<4><1><default><default>
kp_in2 = port:PH10<4><1><default><default>
kp_in3 = port:PH11<4><1><default><default>
kp_in4 = port:PH14<4><1><default><default>
kp_in5 = port:PH15<4><1><default><default>
kp_in6 = port:PH16<4><1><default><default>
kp_in7 = port:PH17<4><1><default><default>
kp_out0 = port:PH18<4><1><default><default>
kp_out1 = port:PH19<4><1><default><default>
kp_out2 = port:PH22<4><1><default><default>
kp_out3 = port:PH23<4><1><default><default>
kp_out4 = port:PH24<4><1><default><default>
kp_out5 = port:PH25<4><1><default><default>
kp_out6 = port:PH26<4><1><default><default>
kp_out7 = port:PH27<4><1><default><default>
[usbc0]
usb_used = 1
usb_port_type = 2
usb_detect_type = 1
usb_id_gpio = port:PH4<0><1><default><default>
usb_det_vbus_gpio = port:PH5<0><0><default><default>
usb_drv_vbus_gpio = port:PB9<1><0><default><0>
usb_host_init_state = 0
[usbc1]
usb_used = 0
usb_port_type = 1
usb_detect_type = 0
usb_id_gpio =
usb_det_vbus_gpio =
usb_drv_vbus_gpio = port:PH6<1><0><default><0>
usb_host_init_state = 1
[usbc2]
usb_used = 1
usb_port_type = 1
usb_detect_type = 0
usb_id_gpio =
usb_det_vbus_gpio =
usb_drv_vbus_gpio = port:PH3<1><0><default><0>
[usb_feature]
vendor_id = 6353
mass_storage_id = 1
adb_id = 2
manufacturer_name = "USB Developer"
product_name = "Android"
serial_number = "20080411"
[msc_feature]
vendor_name = "USB 2.0"
product_name = "USB Flash Driver"
release = 100
luns = 2
[gsensor_para]
gsensor_used = 1
gsensor_name = "bma250"
gsensor_twi_addr = 0x18
gsensor_twi_id = 1
gsensor_int1 = port:PH0<6><1><default><default>
gsensor_int2 = port:PI10<6><1><default><default>
[gps_para]
gps_used = 0
gps_spi_id = 2
gps_spi_cs_num = 0
gps_lradc = 1
gps_clk = port:PI0<2><default><default><default>
gps_sign = port:PI1<2><default><default><default>
gps_mag = port:PI2<2><default><default><default>
gps_vcc_en = port:PC22<1><default><default><0>
gps_osc_en = port:PI14<1><default><default><0>
gps_rx_en = port:PI15<1><default><default><0>
[sdio_wifi_para]
sdio_wifi_used = 0
sdio_wifi_sdc_id = 3
sdio_wifi_mod_sel = 1
swl_n20_shdn = port:PH9<1><default><default><0>
swl_n20_host_wakeup = port:PH10<1><default><default><1>
swl_n20_vdd_en = port:PH11<1><default><default><0>
swl_n20_vcc_en = port:PH12<1><default><default><0>
[usb_wifi_para]
usb_wifi_used = 1
usb_wifi_usbc_num = 2
[3g_para]
3g_used = 0
3g_usbc_num = 2
3g_uart_num = 0
3g_pwr =
3g_wakeup =
3g_int =
[gy_para]
gy_used = 0
gy_twi_id = 1
gy_twi_addr = 0x0
gy_int1 = port:PH18<6><1><default><default>
gy_int2 = port:PH19<6><1><default><default>
[ls_para]
ls_used = 0
ls_twi_id = 1
ls_twi_addr = 0x0
ls_int = port:PH20<6><1><default><default>
[compass_para]
compass_used = 0
compass_twi_id = 1
compass_twi_addr = 0x0
compass_int = port:PI13<6><1><default><default>
[bt_para]
bt_used = 0
bt_uart_id = 2
bt_mod_type = 1
[i2s_para]
i2s_used = 0
i2s_channel = 2
i2s_mclk = port:PB5<2><1><default><default>
i2s_bclk = port:PB6<2><1><default><default>
i2s_lrclk = port:PB7<2><1><default><default>
i2s_dout0 = port:PB8<2><1><default><default>
i2s_dout1 =
i2s_dout2 =
i2s_dout3 =
i2s_din = port:PB12<2><1><default><default>
[spdif_para]
spdif_used = 0
spdif_mclk =
spdif_dout = port:PB13<4><1><default><default>
spdif_din =
[audio_para]
audio_used = 1
capture_used = 1
audio_lr_change = 0
audio_pa_ctrl = port:PH15<1><default><default><0>
[ir_para]
ir_used = 0
ir0_rx = port:PB4<2><default><default><default>
[pmu_para]
pmu_used = 1
pmu_twi_addr = 0x34
pmu_twi_id = 0
pmu_irq_id = 0
pmu_battery_rdc = 100
pmu_battery_cap = 4500
pmu_init_chgcur = 600
pmu_earlysuspend_chgcur = 600
pmu_suspend_chgcur = 1000
pmu_resume_chgcur = 300
pmu_shutdown_chgcur = 1000
pmu_init_chgvol = 4200
pmu_init_chgend_rate = 15
pmu_init_chg_enabled = 1
pmu_init_adc_freq = 100
pmu_init_adc_freqc = 100
pmu_init_chg_pretime = 50
pmu_init_chg_csttime = 720
pmu_bat_para1 = 0
pmu_bat_para2 = 0
pmu_bat_para3 = 0
pmu_bat_para4 = 0
pmu_bat_para5 = 5
pmu_bat_para6 = 8
pmu_bat_para7 = 11
pmu_bat_para8 = 22
pmu_bat_para9 = 33
pmu_bat_para10 = 43
pmu_bat_para11 = 50
pmu_bat_para12 = 59
pmu_bat_para13 = 71
pmu_bat_para14 = 83
pmu_bat_para15 = 92
pmu_bat_para16 = 100
pmu_usbvol_limit = 1
pmu_usbcur_limit = 0
pmu_usbvol = 4000
pmu_usbcur = 0
pmu_usbvol_pc = 4000
pmu_usbcur_pc = 0
pmu_pwroff_vol = 3300
pmu_pwron_vol = 2900
pmu_pekoff_time = 9000
pmu_pekoff_en = 1
pmu_peklong_time = 1500
pmu_pekon_time = 1000
pmu_pwrok_time = 64
pmu_pwrnoe_time = 2000
pmu_intotp_en = 1
pmu_used2 = 0
pmu_adpdet = port:PH2<0><default><default><default>
pmu_init_chgcur2 = 400
pmu_earlysuspend_chgcur2 = 600
pmu_suspend_chgcur2 = 1200
pmu_resume_chgcur2 = 400
pmu_shutdown_chgcur2 = 1200
pmu_suspendpwroff_vol = 3500
pmu_batdeten = 1
[recovery_key]
key_min = 4
key_max = 100
[dvfs_table]
max_freq = 0x3c14dc00
min_freq = 0x3938700
LV_count = 5
LV1_freq = 0x3ef14800
LV1_volt = 1500
LV2_freq = 0x3c14dc00
LV2_volt = 1400
LV3_freq = 0x365c0400
LV3_volt = 1350
LV4_freq = 0x337f9800
LV4_volt = 1300
LV5_freq = 0x25317c00
LV5_volt = 1250
Originally posted by seya_20 View Post
successfully done .. i flashed my tablet and touchscreen realy work's...but camera error firmware uploading..
There are currently 1835 users online. 1 members and 1834 guests.
