[Help] Remote control for EKB368
    Hi, I have tried many free applications to remotely control my Z4 EKB368, but have not worked.
    Can you recommend a free app that functions as a wireless remote control?
    None for EKB368.
    HPH & UGOOS has a Le Home Assistant Remote control app that works very good but it only works with their firmware.
      None for EKB368.
      so I can only use a wireless mouse?
        Yes
          There are a lot of apps that let you control your Android Box with a Android phone. Wukong TV Remote is just one of many that work.
            Wukong TV Remote not work on galaxy tab 3 and ekb368
              You can use Fireasy app for moded firmware mod but you're better off using air/regular extended mouse/gamepad as in this:
              Auf YouTube findest du die angesagtesten Videos und Tracks. Außerdem kannst du eigene Inhalte hochladen und mit Freunden oder gleich der ganzen Welt teilen.
