[ROM] ARNOVA 8G2 8Gb [ROOT, Market, Google apps, ext4 fs, 1Gb user space] by Sowa
    All the actions you do at your own risk!
    In applying the Custom ROM you lose your warranty
    Attention!
    Not suitable for ARNOVA 8G 4Gb
    This ROM is not suitable for a model with a resistive touch.
    Custom ROM version 5.0s release candidate for the ARNOVA 8G2 8Gb
    In the archive:
    - image\AN8G2_v5sRC.img - very flash
    - RK29BachTool_v1.4 - a tool for firmware
    - Drivers - USB Drivers for ARNOVA flashing mode.
    Flash only through RK29BachTool!!!
    Rolling back to the stock firmware is also only through RK29BachTool
    Differences firmware.
    - Sections converted into a format the ext4 file system
    which is much faster read/write data
    allows to edit, add and delete files in it.
    - Set aside for user data 1Gb memory. This will allow
    install more applications.
    With the increasing number of applications increases the start time.
    - Updated some applications.
    Thanks fenice57
    - Added support for modules BT, *
    - 3g USB-modem Hauwei models E1550 E1692 E1750 E1820 *
    * Requires verification and debugging.
    Flashing:
    Connect ARNOVA to the BB via USB-cable.
    At 2 seconds, press the "reset", you hear the sound of the columns twice.
    If the driver is not installed, install it.
    In Windows devices should see:
    | Class for rockusb devices
    -- RK29 Device
    Attention! Be sure to remove the SD-card before flashing.
    Then run RKBatchTool.exe
    Select the firmware and click "Restore"
    Updated the ROM. 14.02.2011 23:55
    - Fix VideoPlayer
    - Fix FlashPlayer
    ROM -> ARNOVA 8G2 8Gb [ROOT, Market, Google apps, ext4 fs, 1Gb user space] (81 Mb)
    Rolling back from the version 4s & 5s with only Rk29BatchTools through the button "Restore"
    User data during installation are removed.
    Dump the standard ROM AN8G2_rkdump.7z
    </form>
    need help
    I have flash arnova 8g2 8gb model: AN8G2, and after reboot he enter to android system recovery and he failed data wipe and stop. when I reboot the tablet , on screen apear ARNOVA and rebotind and reboting, no system ...
    RHandroidTools b1.29 had no errors.
      thanks
      Thanks!!! Great ROM
