Help - screen purple
    Hello to all
    I recently took this fantastic tv player, but am having problems with video display. after a few minutes of viewing any screen, the TV screen will turn purple and remains so for a few seconds and then return as before and this problem makes me cyclically, I tried to vary all the display settings of MINI MX, but concerning these remains. I also tried a second MINI MX but the thing does not change. I also have a MXQ with which I have no problem. I think at this point it is a coding problem of HDMI that conflicts with tv.
    you can help me?
    hello no one knows how to solve my problem
      does it happen only on KODI?
        unfortunately no, it does on the whole system ....
          Test on another TV/monitor if you can, also set input to auto on auto may also work.
          but as you say conflict in TV.
          Cheers
            on another tv I have no problems
              Maybe firmware update of TV if possible but if TV is a little old well convince family time for new one, maybe hard to do.
              You have tried different or lower resolution on media player ?
              Does TV have VGA in maybe HDMI to VGA converter may help
              China-1 Stock | Buy HD 1080p HDMI Male to VGA Female Video Converter Adapter Cable Support Audio Output - Black online at unbeatable prices. ✓Free Shipping ✓Limited Time Sale ✓Local Warehouses.
                I'll try with the cable that you suggested, but I also have a component input to the TV, which adapter I can buy?
                  Google/****/Amazon whatever is easy for you in your area HDMI to Component with audio.
                    Further reading up on this due to some input from another user(and you know who you are ) the above will not work as HDMI to Component, read here,
                    It can but the cost much more like this device,
                    Sorry for any confusion.
                    Cheers
                      thanks for the advice ... I'll try with the component
                        You can find some hint here.
                          No It's the software they use to run their forum, its called vBulletin
