m8s 812 no wifi after installing new firmware
I bricked this box at xmas but revived it through this forum by shortening the nand pins thanks all for that help.. i tried to flash about 15 different firmwares and only 2 work but with no wifi just wondering if there is anyone else with this problem with this board in pictures i have been on the internet about 2 months none stop every night and its doing my head in seller sent me firmware but that bricked it. its just a bad clone that doesnt take to much firmware.any info would be grateful thanks for listening.You may only view thumbnails in this gallery. This gallery has 5 photos.5 PhotosTags: None
I share your pain and it took me a very long time to find the right firmware. It's due to the board having different wifi radio to all other devices.
For anyone with the kca-003 board who has no WiFi or Bluetooth, after much searching and experimentation I found a burning tool image that actually works and I couldn't not share it.
https://drive.google.com/file/d/0B26...ew?usp=sharing
For some reason it didn't boot without using a u-boot.bin on the SD card that I know works but I worked out how to just flash the u-boot and all is fine. You may find that yours boots without the extra step. Good luck!
how are u first of all thanks for the reply back i downloaded img and used the burner tool but as u said it didn't boot straight up now do i just try find a u-boot.bin file that works and format a sd card or do i try use bootcard maker and use a u-boot file that i know that works and put power lead back in or what do i do next thanks for listening...
I didn't use bootcard maker or format the sdcard but I can't say for sure that I didn't use bootcard maker on that particular card a while back. When I get home I'll try to remember to grab the u-boot and and script that I used to flash the u-boot. If it has successfully flashed then it will show the boot logo and reboot after a few seconds and go to a black screen. You wait a minute or so to be sure that it has finished flashing and pull the power. When it starts back up it should boot through to android, after a wait of a few minutes.
When u get a chance to send that file I would appreciate it... when I started the box back up after flashing the img with usb tool software it came up with s802 logo and it froze on that screen I left it for a few mins just in case and no change I noticed the blue light on front panel of my mas box not on even do the logo was stuck on screen I tried a few different script files with u boot bin files and no joy when I pressed in the reset button while putting power lead back the blue light came on screen went black kept finger in reset button for an extra few seconds then released reset button screen went black I taught it was ready to wirk and never went off black screen obviously wrong boot file or something...😠😢😨
There are currently 2647 users online. 1 members and 2646 guests.
