The WeTeK Hub is a small TV Box that fits easily in your pocket. It measures only 7cm x 7cm x 2cm. WeTeK Hub is equipped with SoC from AMlogic
Amlogic S905-H Quad-core 64-bit ARM Cortex-A53 up to 2GHz. Also we find 1GB DDR3 RAM and 8GB eMMC internal memory.
The device has a Dual Boot and runs on Android 5.1.1 and OpenELEC.
WeTeK Hub specifications:
CPU AMLogic S905-H
GPU Mali-450MP Penta Core
Memory 1GB DDR3 RAM
Internal storage 8GB eMMC 5.0 Flash memory Samsung
Connectivity Gigabit Ethernet and Dual Band B/G/N/AC WiFi (external antenna), BT 4.0
Interfaces HDMI 2.0, Micro SD card slot, USB2.0
OS Dual boot Android Lollipop 5.1.1 / OpenELEC, Ubuntu optional
Features:
Google Widevine Level 1, Microsoft Playready + HDCP
1080p DRM video streaming Apps such as Netflix.
Dolby and DTS Licences
10-bit 4K@60Hz HEVC decoding
HD Audio passthrough
External IR adapter to Hide HUB behind a TV, bracket mount available
