I just bought XTOUCH XTV-1. http://www.xtouch.ae/plus/view.php?aid=797
I found it online under the names CX-818 or MK909. Do you have any idea if fineless rom will work?(if yes which one) I need it because I want to update libstage etc. It comes with Android 4.2.1
Stock firmware is here: http://pan.baidu.com/share/link?shar...&uk=3743663504
Thanks for help!
PS: I don't need wifi because I will use LAN.
