I have found a very strange problem, I don't know if this happens in all tablets or in this rom.
I have added CPU control and the Cool Tool to check the CPU speed.
The maximun speed is 1664Mhz . I had put in the cpu control max 1664 and lower 728, when I press activate the spped is 1664 If I work with the tablet the frequency is 1664 but when I close it and then unlock it and try to use it the frequency drops to 1144mhz and remains there as many hours as I use it, to increase the speed again I had to go to cpu control activate the settins again but until I shut it down ( not power off )
In the settings menu, -- battery, in the top there is a "CPU power saving mode OFF" entry , this must be checked or not to have full frequency? but checked or not I don;t see any difference in my case
I had checked all those because I have some small lags when the frequency is 1144. Supposed the tablet must increase or decrease the frequency on demand of the apps but this is not happening
Thanks in advance
