M8S laggy ethernet issues
    Hey guy's 1st post here..
    Just picked up a M8S from amazon to test out and while trying to get my build going in Kodi I noticed hardly anything would auto play like i have it setup on my other boxes and when it did play it would buffer every 30 seconds.
    Long story short after trying everything from kodi 15 to 16.1 to see if that was the issue even put in my read debrid info.. I decided to try wifi instead of Lan..
    turns out that seems to have been the issue. Both wifi and ethernet get aprox 20mbps down from a speed test. .. the same for all my other boxes that everything runs fine with.
    Seems very odd that Wifi beats out Lan and would prefer Lan for this box.. Any Ideas ?
    info on its build
    Model number m8s
    Android Version 4.42
    Build m8s.bcm4335.20161252036
    Kernel 3.10.33
    use a custom rom
    Bugs are Sons of Glitches!
    JustMe
      Were can I find a custom rom?
      Verstuurd vanaf mijn SM-G925F met Tapatalk
