MX2 box HD18 v2.22 with A13 v1.0 - Anyone have a fix for: error, the rtc serial communication abnormal, reset the rtc!
    Just wondering if anyone has fixed an MX2 HD 18 v2.22 with A13 v1.0 that gives the following
    Code:
    [   14.239765@0] SD/MMC initialization started......
    [   14.878937@0] mmc data3 pull high
    [   14.879157@0] sd_mmc_info->card_type=0
    [   14.880347@0] begin SDIO check ......
    [   14.906562@0] sdio_timeout_int_times = 0; timeout = 498
    [   14.929158@0] sdio_timeout_int_times = 0; timeout = 497
    [   14.929185@0] SEND OP timeout @1
    [   14.931949@0] mmc data3 pull high
    [   14.935437@0] begin SD&SDHC check ......
    [   14.981497@0] sdio_timeout_int_times = 0; timeout = 498
    [   14.981527@0] SEND IF timeout @2
    [   15.007046@0] sdio_timeout_int_times = 0; timeout = 498
    [   15.007074@0] begin MMC check ......
    [   15.051508@0] sdio_timeout_int_times = 0; timeout = 498
    [   15.051539@0] No any SD/MMC card detected!
    [   15.055172@0] #SD_MMC_ERROR_DRIVER_FAILURE error occured in sd_voltage_validation()
    [   15.062842@0] [card_force_init] unit_state 3
    [   15.062853@1]
    [   15.062856@1] SD/MMC initialization started......
    [   15.073562@0] [dsp]DSP start addr 0xc4000000
    [   15.077685@0] [dsp]register dsp to char divece(232)
    [   15.087253@0] DSP pcmenc stream buffer to [0x9e001000-0x9e201000]
    [   15.088599@0] amlogic audio dsp pcmenc device init!
    [   15.094360@0] amlogic audio spdif interface device init!
    [   15.202808@0] error, the rtc serial communication abnormal, reset the rtc!
    [   15.307882@0] error, the rtc serial communication abnormal, reset the rtc!
    [   15.412952@0] error, the rtc serial communication abnormal, reset the rtc!
    [   15.518038@0] error, the rtc serial communication abnormal, reset the rtc!
    [   15.623112@0] error, the rtc serial communication abnormal, reset the rtc!
    [   15.728188@0] error, the rtc serial communication abnormal, reset the rtc!
    [   15.833255@0] error, the rtc serial communication abnormal, reset the rtc!
    [   15.938358@0] error, the rtc serial communication abnormal, reset the rtc!
    [   16.043443@0] error, the rtc serial communication abnormal, reset the rtc!
    [   16.148523@0] error, the rtc serial communication abnormal, reset the rtc!
    This is a hardware problem, which is not a big problem actually.
    It happens because of a broken crystal quartz resonator which worck for RTC module.
    I have tried unsoldering one from a PCi modem, but then realised that it has other frequency (for data modelling).
    Then I've found an old pc motherboard in a storage, and there was the one I really need. Now it does not give this error, so I can keep going to next stage unbricking it.
    Usually they put this crystals in any chinese clock, or any electronics that have time modules in
      I have fixed it! Its a problem in the quartz crystal resonator, just unsoldered it from an old motherboard's RTC.
        What is the value of the crystal?
          A RTC crystal is typically 32.768 KHz.
          And whomever designed that board needs to give up their EE license. Jeez.
