During the installation of RileyRom1.9, everything was going fine, but the tablet did not reboot properly. Now it has black screen with the Android logo in the middle and the green tiny robot image has its front cover open and an exclamation mark on it. I did reset with a niddle from behind, I press simultaneously Volume+ +Reset buttons or Esc+ reset and the same image of the grren robot appears. Is it totally broken or can I do something more ?
P.S. ROMFLASH tool is not visible anymore.
