On a wider note is it possible to write a custom rom that is standard Bios Based pc system with witch you could pixie Boot ( to be use in conjunction CCboot or a pixie server) or to install win7/Linux on to. The ROM would Need to incorporate appropriate drivers for win 7 ect
Then you would be able to install you own os systems but more importantly could pixie boot the same image across several mbox'es meaning when you make changes they happen accorss all machines
Also this might be a bit far what's the chance of a MBOX Base ROM incorporating Grid Computing ( Tieing all the mbox processors on a network together) so when it boots its finds other mbox's on the network with the same rom and share the processing power between the machines this would only Really be advantageous on the RK3368 BOX as it Gigabit Network socket but over all would give you an extremely powerful home media network giving you processing power where its needed Cheers
