I've a common squared M8, pcb M9&M8_v0.92, which failed whilst updated using SD card (to be honest I pulled the power as I had a blank screen for about 15 mins).
Now all I get, is a brief blue flash from the front light when power is plugged in and out, blank black screen on TV.
I've followed a few How-To unbrick threads, from which I've tried ..
1. Shorting pins 7&8 and attempting another SD card update - nothing happened at all
2. Plugged OTG USB port to a PC, then using the flashing tool, it was recognized and I tried to flash to the probox2 img to it, but it always fails at around 4% (this was still with the pins 7&8 shorted - I didnt need to short the OTG jumper in order for it to be recognized)
The brief blue flash from the front light isn't a symptom I've come across in my searching (most say blue light on, but blank screen) Is this the definition of Hard Bricked ?
If you can advise on what state it's in or how can it be brought back to life, it would be much appreciated.
