NEXBOX MXQ PRO Amlogic S905 Android 5.1 4K Smart TV Box 1G/8G 802.11b/g/n LAN XBMC H.265 HDMI Miracast DLNA Dolby DTS
    Just when you thought we had enough s905 alongs comes another
    MXQ Pro is a smart Streaming Media Player with Android 5.1 Lollipop OS, powered by Quad core Amlogic S905 Cortex A53, includes a Penta-Core GPU that can reach speeds of up to 2.0GHz. Support 4K Ultimate HD vedio hardware decoding. With preinstalled Google Play Store and other apps, you can enjoy smooth multi-tasking, game playing or movie viewing
    CPU: Amlogic S905 Quad-Core Cortex A53 28nm Processor 2.0GHz
    GPU: Quad-Core Mali-450
    OS: Android 5.1 lollipop
    Support H.265 hardwar decoding, H.264 up to 4K 30Hz
    Playstore, XBMC preinstalled
    Support Miracast DLNA
    Supports Dolby and DTS
    Anyone used this box? Any feedback is welcome...
      I don't know about this one but the n9 is pretty good
        ordered from Gearbest.com,
        shipment is on the way, will write a review when receive it.
          Firmware supports for this box is very limited as it's using p200 board. No OTA update.
            NEXBOX MXQ PRO AMLOGIC S905 ANDROID 5.1 4K SMART TV BOX FIRMWARE 20160520
            New firmware
            blog.geekbuying
              New firmware
              blog.geekbuying
              Be careful, the download link in geekbuying blog is wrong, this is not a MXQ pro rom but a KK rom for older mxq (s805) I think...
                Slowry oh thanks.. that may explain why I can't flash it
                  Finaly found working firmware: https://mega.nz/#!VdVTWKpA!f-69dJP3w...YcS-d_W47HLAwA
                  you need to remove the Chinese symbols from the image file or you may get a parse error.
                    Some pics from the inside: http://freaktab.com/forum/tv-player-...d-5-1-openelec
                      Anyone noticed that when you press the Home button while in some app it closes that app completely. No background process left behind. So, when you run that app again it starts from the beginning. That means that you cannot work on 2 (or more) apps simultaneously?!
                        You can delete /system/etc/allowbackgroundapp.list or rename
                          prahjister, thank you very much!
                          It works like a charm
