Update 20160304 MRX 2GB + 16GB Firmware Download
    MRX 2GB + 16GB firmware (USB Burning) download link:
    Flash tool download link:
    http://www.mediafire.com/download/ek...v2.0.5_x86.exe
    MRX 2GB+16GB firmware (SD Card) download link:
    http://www.mediafire.com/download/36...04_SD_card.zip
    Get ROOFULL MRX TV Box by Amazon USA store:
    http://www.amazon.com/Streaming-Play...ywords=ROOFULL
    Is there a sd card update available and if so will it work on the 2gb/ 8gb version of the mrx as well ?
      Hi, I have added the SD card firmware update. You can try the newest firmware on your 2gb/8gb MRX TV box, we tested it successfully.
        Thanks, good job. Compared to the old version works better. Now it works and some of addons for Kodi. Quasar, Torrenter on the old version does not working. Still problems with the "mouse" button on the remote and VGA output does not have video signal.
          For Kodi addons, you can customize it by yourself OR install ROOFULL Wizard addons to one-click install the newest Addons data by here: http://freaktab.com/forum/tv-player-...ur-kodi-addons
