Need fix for my Beelink BT3 deleted audio driver
Help!...I accidentally deleted the Everest ES8316 sound driver for my box. I cant find an installation tool to restore the driver and get the following error message: ACPI\ESSX8316\1 REQUIRES FURTHER INSTALLATION. Any help much appreciated.Tags: None
ES8316AudCodec-Device-15.3.24.922.zip
Hi - See if this helps. Im also having trouble with my BT3 after a Win 10 reinstall.
No sound, this driver is installed ok, but Im not seeing any audio devices for playback.
Can you share what you have installed?
Success I have sound again!!
Jack - try this driver -
In Device Manager, under Other Devices I had a problem entry with no details but in properties it had Device Instance path = ACPI\808622A8\1
This was the problem Intel SST Audio Device.
Using your details I found this Lenovo Driver pack and installed that (http://support.lenovo.com/gb/en/downloads/ds040016)
I then tried to update the driver for the Intel SST Audio device and pointed setup to the folder (C:\DRIVERS\WIN\Chipset) and the driver updated successfully.
Hope this helps.
These are my two audio devices drivers back up...
Intel-SST-Audio-Device-(WDM)-604.10135.2747.5232.zip
There are currently 2303 users online. 0 members and 2303 guests.
