Fixed - Im looking for MXQ Pro rom (my remote stopped working after changing rom)
FIXED the issue! See my 2nd post below for more info!Last edited by Chaosstorm; 03-31-2016, 16:25.Tags: None
My issue was that i flashed a p201 image with image burn tool and I only had p200 ota firmwares which i could not flash by zip since it thought that my device was a p201.
1: I followed the info from this post below:
2 : In the link below is a mxq pro quick play which is nearly the same is my mxq pro 4k.
3: I contacted my seller on aliexpress which send me a dropbox link with the latest MXQ Pro 4k update and there, my remotes works fully again and i even updated it .
OLD - only use this if you cant find or flash your original mxq box firmware.
I've learned somethings. there is a file "Remote.conf" that is different for some MXQ boxes.
However the power button for turning the box on is handled by the bootloader, so this only fixes most things in android.
Copied this from xda developers:
Using a file explorer, a good one is ES explorer, check if you have the following file
/etc/remote.conf
This remote.conf file worked for me:
#this file is configuration for each factory remote device
# work_mode 0 :software mode 1 :hardware mode
# repeat_enable 0 :disable repeat 1 :enable repeat
# factory_code each device has it's unique factory code.
# pattern:custom_code(16bit)+index_code(16bit)
# examble: 0xff000001 = 0xff00(custom cod) 0001 (index)
# release_delay unit:ms.release will report from kernel to user layer after this period of time
# from press or repeat triggered.
# debug_enable 0 :debug disable 1 :debug disable
# SW MODE:
# bit_count how many bits in each frame
# tw_leader_act time window for leader active
# tw_bit0 time window for bit0 time.
# tw_bit1 time window for bit1 time
# tw_repeat_leader time window for repeat leader
# REG
# reg_base_gen set value for PREG_IR_DEC_BASE_GEN
# reg_control set value for PREG_IR_DEC_CONTROL
# reg_leader_act set value for PREG_IR_DEC_LEADER_ACTIVE
# reg_leader_idle set value for PREG_IR_DEC_LEADER_IDLE
# reg_repeat_leader set value for PREG_IR_DEC_REPEAT_IDLE
# reg_bit0_time set value for PREG_IR_DEC_BIT0_TIME
#amlogic NEC remote
factory_code = 0x7f800001
work_mode = 0
repeat_enable = 1
repeat_delay = 40
repeat_peroid = 39
release_delay = 121
debug_enable = 1
fn_key_scancode = 0x15
left_key_scancode = 0x1c
right_key_scancode = 0x48
up_key_scancode = 0x44
down_key_scancode = 0x1d
ok_key_scancode = 0x5c
pageup_key_scancode = 0x04
pagedown_key_scancode = 0x1b
mouse_begin
0 0x1c
1 0x48
2 0x44
3 0x1d
mouse_end
key_begin
0x4d 113
0x56 114
0x4e 115
0x25 105
0x26 103
0x27 106
0x28 108
0x0d 97
0x1b 158
0x53 102
0x51 704
0x49 139
0x52 388
0x31 2
0x32 3
0x33 4
0x34 5
0x35 6
0x36 7
0x37 8
0x38 9
0x39 10
0x30 11
0x58 389
0x44 14
0xbd 122
0xbb 123
0x09 393
0x11 390
0x54 391
0x4f 392
key_end
repeat_key_begin
0x4d 113
0x56 114
0x4e 115
0x25 105
0x26 103
0x27 106
0x28 108
0x0d 28
0x1b 158
0x53 102
0x51 704
0x49 139
0x52 388
0x31 2
0x32 3
0x33 4
0x34 5
0x35 6
0x36 7
0x37 8
0x38 9
0x39 10
0x30 11
0x58 389
0x44 111
0xbd 122
0xbb 123
0x09 164
0x11 390
0x54 391
0x4f 392
repeat_key_endLast edited by Chaosstorm; 03-30-2016, 22:21.
There are currently 2067 users online. 6 members and 2061 guests.
