Huge problems
Originally posted by RISCy Dude View PostI have used the Ugoos AM1 firmware on the Meta. Should work on the Telos. I don't know if it will address your issues, but might be worth a look. It is a USB flash.
I m already dowloading, i will let you know, after the flash. Lets hope it will work...
Update:
Again the same mesage... I am really dissapointed!!!
Originally posted by MIKermit View Post
Thanks!
So i need to flash again the Finless. Is it possible with the burning tool? Because its the only method i can falsh. Another option is to flash a newer tronsmart rom, but i can't find any url, so i will try with the beta...
I just flashed to latest tronsmart rom 3/09 build coming from stock rom and i did get that same error you are getting. I had to flash finless rom via sd card first before it would let me flash 3/09 build. I think it has something to do with mac key being the same as the key you used to install previous rom. Have tried the overwrite key option or unchecking bootloader option when flashing?
I gathered you weren't able to boot up to use SD card. If you are able to get into recovery that may work to update. You just need to browse to the SD card. As for the mac key thing...if you look at your previous post with the screen shot. You will see on the right side there is a mac and key. I think your key # is 367. So what I have noticed after flashing finless rom is that the key is different than the key used for tronsmart roms. So my thinking is that if you trying to flash from tronsmart rom to another tronsmart rom. They might be using the same key which is causing the error and you might want to try in USB flashing tool to check the overwrite key option or change some other options in that configurations section to see if you can get the flash to go through.
There are currently 2305 users online. 3 members and 2302 guests.
