Is there anyone who could successfully flash xposed framework on a tronsmart / beelink r68 or r68g?
I am trying to flash xposed framework, however:
1. If I flash xposed v80 sdk 22 arm, I cannot run any app after booting up again. The screen flashes and nothing happens. Anybody can guess what is the problem?
2. If I try to flash xposed v80 sdk 22 arm64, it gives an error to download correct sdk, which means arm64 version isn't compatible with this version of Android. And that means the version of Android shipped with this box is 32bit.
But why flashing 32 bit ends with not being able to run any app? Any suggestion? Or if someone could manage to install xposed on a rk3368, please tell me how did you do it :-)
Ps: I'm on stock firmware 206L1
