Anyone out there having this problem? Any suggestions? Is this possibly a result of installing a custom firmware or just hardware malfunction? Any way to check?
wifi wont turn on
wifi wont turn on
I have flashed several different firmwares on my ekb368 device since I purchased it in January. I settled on the 12-22 and find spmc v15 works best. Anyhow I've been using an ethernet connection for this device and just realized the wifi wont turn on. I've tried to do so through settings and the drop down menu. Neither work. In settings it says "turn on wifi to view networks" or something like that. When I press the on button it says "turning on wifi" then back to "turn on wifi to view networks" I honestly don't remember if this was working when I first got the box. In my attempts to fix this I've flashed different firmwares and cleared the cache and data from the recovery menu but nothing works. Bluetooth works fine.
Anyone out there having this problem? Any suggestions? Is this possibly a result of installing a custom firmware or just hardware malfunction? Any way to check?Tags: None
There are currently 2979 users online. 0 members and 2979 guests.
