sos pipo m8pro
Originally posted by neomode View PostNormally the USB Specification says 500mA for each Port.
This means that a lot of External USB Harddrive wont goes on.
What you need is a External Power Supply for your Hard Disk or a USB Hub.
Neomode
ok my fear and it's just a problem of my m8pro
while I would like to know if they work on other m8pro
since it's new I would change
- A power supply for your harddrive (goes in the wall socket or portable power bank).
If this is not possible (some portable drives don't have power connectors) then: - A powered USB hub connected to your tablet/phone, powered by wall socket.
- For complete portability, a powered USB hub wich gets its power from a portable power bank.
Last edited by pr0xZen; 09 June 2013, 15:38. Reason: Turns out some tablets might be able to drive low-power-consumption drivesSupport your local flasher
Current devices : Pipo MAX M8 Pro - Samsung Galaxy S4 - Intel NUC
Originally posted by pr0xZen View PostOn a COMPUTER, maximum output for a USB connection is 500mA. This is NOT the case with tablets or phones. An external harddrive needs MUCH more power than ANY tablet or phone will be able to supply through USB connection. Your choices are the following:- A power supply for your harddrive (goes in the wall socket or portable power bank).
I tried 5 hard disk 2.5'' powered on two other tablet that work perfectly without extra power supply
He is currently using Samsung Note 10.1 and Samsung Tab 10.1, none of these can supply enough current to power an external drive.Support your local flasher
Originally posted by pr0xZen View PostPlease let me know exactly wich other tablets these were, and the type of harddrives. I have a friend wich needs an effective tablet platform with external large-capacity storage, and he would be very glad if he didn't need the power bank and hub anymore.
sorry I was out for a moment
tested with flytouch9 and with ondav972
harddisk tested verbatim 1tb iomega 500gb western digital passport 500gb
There are currently 2069 users online. 0 members and 2069 guests.
