OTG USB-hub searched
    Hi community,
    I´m searching an OTG USB hub for my CX998 device.
    All I can find is with an USB-B cable, but I only have an USB-A connector for OTG.
    I have an old USB hub (for PC), but this one doesn´t work as OTG.
    May be there is a possibility to solder another cable to the hub, but in this case I need to know the pin which is necessary to switch to OTG.
    Need some help with this issue, please...
    Use a OTG Adapter and Connect the Hub to it.
    Then you are ready to go.
    Neomode
      Thanks neomode
      I figured out that the OTG on my device works not as expected. I plugged the hub to one other both USB connectors and it works fine so far.
      The bad working OTG connector does not affect the connection to my PC, so I´m fine.
