Deciding which Media Center to use is sometimes quite a bit of a headache. Here follows my reasons (and I could be a bit bias due to the fact I also have a Zidoo X6 and it is rock solid!) for using ZDMC.
- SPMC hangs when exit, ZDMC does not.
- SPMC crashes when terminating hung state, causing system to reboot.
- ZDMC (in default state) will not display video, but plays audio, on certain files. Disabling the "RockchipCodec" under Settings/Video/Acceleration fixes this.
- Android still has a delay between Audio and Video. this can be fixed by starting a video, choosing the audio settings and changing/adjusting the Audio offset, applying it to all files, at the bottom.
kind regards
cyber7 (aka Aubrey Kloppers; Cape Town; South Africa)
