dualOS ROM -> dualOS_Lollipop_Xubuntu-16.04-BETA2_v160403
    Another dualOS ROM for Geekbox ..
    Maybe the last one until Ubuntu 16.04 LTS FINAL will be released .. It's planned for April, 21
    dualOS_Lollipop_Xubuntu-16.04-BETA2_v160403_update.7z
    - Based on Geekbox Lollipop_Beta_V160124
    - Automatic TWRP installation on first boot !
    - Updated SuperSU ( BETA-SuperSU-v2.71-20160331103524.zip )
    - Fresh compiled kernel from today
    - Added L3 WideVine DRM ( Thanks to lonix @ freaktab.com )
    - Based on Ubuntu Xenial 16.04 - BETA2 - ARMHF
    - Autologin into Xubuntu Desktop
    - VNC server activated -> no password required !
    - user "root" and "geekbox" have the same password -> geekbox
    - Auto connection for eth0 via DHCP
    - Wifi needs just to be enabled and configured via network icon.
    - Bluetooth should work as well - not tested.
    You need to reboot manually from Linux to Android .. via terminal.
    Code:
    sudo reboot android
    It´s an update.img for installation via geekbox/rockchip flash tools for linux/windows.
    Like always, you can extract all the partitions and install them one-by-one or build your own firmware.
    Download: https://onedrive.live.com/?authkey=%...42EE9E65C3FAF6
    Have fun !
    Could anyone upload working update.img with Ubuntu 16.04 armhf please?
    Thanks in advance
      You can just flash the rootfs with twrp or androidtool followmsi has it in his drive or you can use mine https://onedrive.live.com/?authkey=%...42EE9E65C3FAF6 and/or (my Google drive fork of his to follow in edit)
