Anyone knows how can I recover the TV box?
Z68 bricked
Couple of things (and please excuse the questions, I can see you are not a novice):- When you ONLY have the OTG and PC connected (no other cables) - do you get anything in your PC's Device manager? (Example: unknown Device, Android device,...)
- When you boot with ONLY the OTG cable and PC connected holding the RESET BUTTON in Do you see any changes in your PC's Device Manager?
- When you push a pin/stick into the reset hole, do you hear/feel a click?
- Have you tried switching the unit off for a while/till cool and tried again?
cyber7
ps - I have taken my unit through some heavy experimental and find no problems, but then, when I ordered, I FORCED Geekbuying to test the unit extensively before shipping, which they did. (It took almost a month before they shipped becuase they had problems, which they never told me about...)kind regards
cyber7 (aka Aubrey Kloppers; Cape Town; South Africa)
http://www.cyber7.co.za / http://aubreykloppers.wordpress.com
Originally posted by cyber7 View PostCouple of things (and please excuse the questions, I can see you are not a novice):- When you ONLY have the OTG and PC connected (no other cables) - do you get anything in your PC's Device manager? (Example: unknown Device, Android device,...)
cyber7
The first two questions I can´t answer. I remmeber that I saw some messages but I'll test and then share the results.
- 3rd question -> YES
- 4rd question -> YES, with the same result
Thank you again
Originally posted by Txemoto View Post
Thank you for the rapid answer.
Thank you again
As a PS: The Rockchip devices is basically brick-free. If you have a look through all the forums you can get on the RK chips, you will see no real bricked devices, rather devices that needs to be re-flashed, which is good news to all RK users...kind regards
Originally posted by Txemoto View PostAfter few hours of use and without change the stock firmware, suddenly, the box shut down and the led went to red. After that it doesn't boot and I can't put in bootloader mode to install an another rom.
Anyone knows how can I recover the TV box?Last edited by vlado; 04 April 2016, 18:20.
cyber7 I've tried to plugin USB cable and when I've plugged USB the led was blue and Windows sounds heard. I had forgotten in a drawer several days ago.
I've plug and unplug from USB, and in the third time red led appeared and no more recognized by Windows. This confirms that it is a hardware problem, isn't it?
Originally posted by scooter2014 View Post
Thank you, but it is not a firmware update problem. The brick came suddenly without update the TV Box.
And now I can't flash it neither power on.
Be careful with this box. It can be bad luck or not....
I had similar when trying unbrick it. Windows driver flaky i re installed drivers set pin plug in ota no power supply. It see device again i re flash. Hope it works for u if not send back to manufacture they take back one if mine after 3 months that diedMany devices now mk902ii/Shield/Mk68 /Ugoos/neox5/minix5 (yes they still work lol) mk80 no it doesnt work lol.
Hi gefattern, thanks for your feedback. The device is detected in Maskmode, I have the ROM, but in the moment I try to Restore it says "Prepare IDB Fail". And the light is still blue. Nothing happen even with the remote control. Impossible to enter in recovery mode. I'm using the 4.4 Drivers, 2.35 Android Tool, and RKBatchtool 1.8, do you need some screenshots? Thanks
Hi mauriale ,
so if you connect it it says MaskromMode not LoaderMode in AT Tool , how do you connect the Box , with shorten pins or normal ,
please "eraseFlash" with AT Tool before restore , wait till ready , press upgrade .
How to connect a RK Device if Drivers and Rom is ready , press Recovery (hold) , connect OTG to PC , connect Power , if connected
in LoaderMode leave Rec. Button .
http://ugoos.net/blog/rockchip-firmw...flashing-guide
a second How to .
good luck
gefattern
a second How to .
good luck
gefattern
There are currently 1743 users online. 0 members and 1743 guests.
