please can some please help
HELP!! 2 M8 Boxes Bricked.
Hi all, Pleae i need help with my m8 boxes. i think i tried to installed wrong firmwares on them and i think they are briicked. when i plug in the power supply, the blue lights blinks won't come on. but i see the red light from the optical port and also the Ethernet port leds comes on and off for about 4 times then stays on. when i unplug the power plug the blue led in front blinks also. i have tried various methods online to see if i could unbrick it but nothing has worked. the weird thing is when i tried the nand pin trick the blue lights comes on and the optical lights goes off but immediately i take the pin i use to shot the nand out it goes back off.
please can some please helpTags: None
Hello guys i finally got one of them fixed through the usb burning tool but the other one is a m8s, will not go past 2% i have tried both the probox2 and the Justme image files but never seeem to go past 2%.
please see image and what can i do.You may only view thumbnails in this gallery. This gallery has 1 photos.1 Photo
Because you have not rom for device or bad nan. You say you have m8s box you need to try finlessbobs rom in this amilogic section or your factoy firmware. Sound like device righting to wrong chipset 802 not 812. Re check maybe box a clone not both identical.Many devices now mk902ii/Shield/Mk68 /Ugoos/neox5/minix5 (yes they still work lol) mk80 no it doesnt work lol.
more details what m8 box and what wifi chipset and operating system and weather you are using usb 2.0 or usb 3.0 and what version of USB BurnToolBugs are Sons of Glitches!
JustMe
There are currently 2261 users online. 10 members and 2251 guests.
