Thanks for any help
Is there a Root Kit for s805 MXQ M201 ?
Originally posted by qq3y6Hi guys I'm looking for some kind of ROOT KIT for the solid black s805 MXQ M201
Thanks for any help
EDIT:Having issues uploading the file.. I'll try to find a link to the source I found it from.
EDIT: found it.. I had used the file given.. Just download the zip to an SD card. Reboot to recovery & flash.. You should have SuperSU installed after the device reboots..
& yes I'm aware it says it works for S802 devices yet I had no issues during the install..
Thanks.
There are currently 6021 users online. 2 members and 6019 guests.
