I've bought a few of these M8S boxes and seems like each one has a different board inside so I never know what to flash on them.
Bricked M8S+
Originally posted by ozzman666 View PostThanks so much for this firmware, been looking everywhere trying to find one to bring this board back to life and this did it.
ozzman666 If you get ethernet running on the box can you let me know? I have WiFi but no ethernet.
Originally posted by dankec View PostEverything is working fine with this firmware on my box. If you like to use openelec just replace firmware on SD card and do the same procedure (toothpick method). Works great!
I would give Openelec another try, I just don't want to download the wrong version again. It was a 5 day headache getting my box back to a working state. Maybe I will try an older version.
Back to USB Buring again.
Originally posted by ozzman666 View PostNo go on the ethernet for me, I'm assuming its because this an M8S+ firmware which has the gigabit LAN port and my box is an M8S variant with
Thanks for letting me know. I will try and see if I can or hopefully someone can help out with getting the ethernet running. Hopefully there is zip file that can be flashed to overwrite the ethernet files in the ROM. If I find anything I will be sure to let you know.
Originally posted by XCH View Postthank so much for bringing my M8s+ back to life!!
Strange thing is i can flash it to Openelec tried 6.0.0 and 6.95.1 etc etc no matter what the box will brick someone have any ideas.
Originally posted by charlesbronson View Post
I found the Openelec OS to flash and work great but the second I turn the box off it would not start up again. I am not sure if it's because they are clone boxes or what the issue is.
ive been trying to get my m8s unbricked for a bout a week now, and finally registered to get some help
ive attached pictures so you know which box it is
on the cover it says m8s but when i opened it up it says m8 V8_8
i can get it recognised by my windows laptop but it gets stuck on 2% so im assuming im using the wrong image.
The thing is i dont even need to hold down the a/v hole with a pin whilst pluging into the power, its automatically in recovery
i may also add, ive got no blue light
Any help would be hugely appreciated as this is not my box as i am borrowing it =[You may only view thumbnails in this gallery. This gallery has 2 photos.2 Photos
There are currently 3498 users online. 3 members and 3495 guests.
