ZIDOO X9S & X8 Mini New Flagship Model with Android 6.0 + OpenWRT powered by Realtek RTD1295 HDMI2 In & Out
    ZIDOO X9S TV Box specifications:
    • Case – Aluminium alloy
    • CPU – Realtek RTD1295 Quad Core Cortex-A53 64bit
    • GPU – T820 MP3
    • Memory – 2GB DDR3
    • Storage – 16GB eMMC
    • Video output – HDMI 2.0A output, HDMI 2.0 Input(Record and streaming)
    • Interfaces – Spdif *1, Cvbs output, USB 3.0*1 ,USB 2.0 *2,Built in SATA 3.0, Built in 1 * RJ-45 Ethernet Jack (10/100/1000Mbps)
    • Connectivity – 2.4G/5.8G 802.11ac dual-band WIFI, Gigabit Ethernet 10/100/1000Mbps, BT 4.0
    • Support – IR TX/RX
    • Power – 12V/2A
    • Android 6.0 + OpenWRT (Hardware router, Samba server) dual system run simultaneously
    • Support HDR, Support HEVC(H.265) 10Bit 4K@60fps,Support VP9,Support BDISO/MKV/
    • Built in ZDMC(Base on kodi 16.0)
    • Support 1080P h.264 Encode
    • Support automatically frame switch
    • Support pass-through 7.1c
    The quad core Cortex A53 CPU combined with the new Mali T820 MP3 GPU (up to 4 sharder cores, 40% improvement from Mali-T622) will offer enough processing power for 4KP60 and H.265/VP9.
    Gigabit Ethernet, SATA and USB 3.0 are all useful when playing files with higher bitrates (H.265/4k2k are to be even more popular in 2016). While there’s no mention about HD audio on the current specs sheet, we do saw that Widevine, Playready, Verimatrix will be supported.
    Realtek RTD1295 will find it’s why not only on TV boxes but also on OpenWRT routers and next generation NAS devices. That makes sense, as NAS devices evolved as well to become full-fledget media centers and might benefit from Realtek 1295’s video encoding and decoding power. Don’t be surprised if you will see Western Digital, Buffalo or Qnap NAS devices powered by Realtek RTD1295 one year from now.
    Source:MinIPCDB
    Also Found at: Source: Androidtvbox
    RTD1295 looks promising indeed - I got some feedback from an early tester and image quality is very good.
      Any news?
      Free 100Gb space for your files:
      https://degoo.com/g/Ov7nAz0
        End of may is about all they are saying at the moment.
        Cheers
          A Zidoo X9S on the way
          The Zidoo X9S is playing a HDR movie, the TV detected the HDR content.
          Source:Zidoo
            A redesigned ZidooTheater APK will be preinstalled in Zidoo X9S
              Ok now i have to pre order damnit....
                More Information on the Realtek RTD1295
                Source armdevice.net
                  Zidoo X9S and Ziddo X8
                  The specifications the Zidoo X9S is the flagship model and has all kinds of connections, this TV-Box is made ​​entirely of aluminum ,
                  2GB of RAM and 16GB of eMMC storage. We have a connector USB 3.0and two 2.0 connector SATA ,
                  Optical audio output, SD card reader,
                  HDMI 2.0A output and HDMI 2.0 input that records up to 1080p, has Gigabit Ethernet and wireless dual - band 2.4 / 5GHz with integrated Bluetooth 4.0.
                  Model Zidoo X8 is made ​​of plastic and offers similar specifications but in this case we have 2GB of RAM and 8GB of storage eMMC,
                  This model we have no SATA connector. This format SoC can decode H.265 with 10bit color , also it has change automatic screen refresh and features a special version of
                  KODI developed by Zidoo that has hardware acceleration. We hope soon to have final price and release date.
                  Model 1 X9S
                  CPU Realtek RTD1295 ARM Cortex-A53 Quad-Core With floating-point unit and NEON SIMD engine embedded
                  GPU ARM T820 MP3 (3-core)
                  Memory 2GB DDR3
                  Internal Storage 16GB eMMC
                  wifi Connectivity IEEE 802.11a / b / g / n, 802.11ac, 4.900 GHz ~ 5.845 GHz (5.0 GHz ISM Band) RTK8821 dual-band WIFI
                  Ethernet 1 * RJ-45 Ethernet Jack (10/100 / 1000Mbps)
                  Bluetooth BT4.0
                  HDMI Port HDMI2.0a output, 4K @ 60fps Support Support HD Audio (7.1CH), support 23.976 and 29.94
                  HDMI2.0 input, PIP support, HDMI IN stream recording and stream output via UDP / RTSP etc ...
                  decode Video HDR, 10-bit HEVC / H.265 up to 4K @ 60fps, VP9 up to 4K @ 60fps, H.264 up to 4K @ 24 fps, automatic frame rate switching
                  audio decode support HD audio (7.1ch) decode and passthrough
                  USB 1 * USB3.0
                  2 * USB2.0
                  Power 12V / 2A
                  other interface 1 * TF card reader SD card interface. Support 1GB / 2GB / 4GB / 8GB / 16GB / 32GB
                  1 * IR receiver
                  1 * Composite video and audio port
                  1 * S / SPDIF (2CH, 5.1CH)
                  1 * SATA3.0
                  1 * VFD display
                  Model 2 X8
                  Memory 2GB DDR3
                  Internal Storage 8GB eMMC
                  Bluetooth BT4.0
                  USB 1 * USB3.0
                  2 * USB2.0
                  Power 12V / 2A
                  1 * IR receiver
                  1 * VFD display
                  Source androidpc
                    So only differences between the two are case, storage 8/16, SATA and antenna count?
                    Glad to see they will offer us pennypinchers a budget solution. Depending on the price difference, I'm willing to make the sacrifices listed.
                    Any ETA?
                      Zidoo X9s or X8 end of month I recall yes could be a bit of fun
                        Still no release and price update?
                        Sent from my GT-I9190 using Tapatalk
                          Did this box die? No news
                            No I think its about to happen soon
                            The Zidoo X9S have been put online on official website, after a prolonged endeavor, the product have been complete more and more.
                            Achieved the 7.1 pass through via ZDMC.
                            Developed a feature-rich player with a powerful subtitle and audio track and 3D playback support.
                            Improved HDMI IN recorder and make it easier to use.
                            High-end components on the board and creativity added a RTC battery.
                            http://www.zidoo.tv
                              If I purchased a box, that worked right out the box, I would go nuts. I have to have something to tinker with, and go bonkers when these boxes still wont do what they should. My inexpensive R-box (after finally getting proper firmware), runs great, not a single problem. So, since it works great, I never use it...... hahaha, is that nuts??
