Looks like I need a bit of help.
Let's start with U30gt2 With 900ss's 4.2.2v4 Was running just fine, The it turned off and wont turn back on....
I have seen signs of life intermittently... Ie every once in a while it will decide to try and boot. But usually gets stuck on the bootloader screen" resistance is futile " with no flashing lights.
Once it even loaded all the way up , but the second I plugged it in to USB to try and back up some of my stuff it crashed!
When I plug it in to a PC ( the same one I used to flash rom's before ) the Flash tool says "Found RKAndroid Mask ROM Usb"
It will not let me reboot to flash or falsh... says" Device can not falsh mode, Because it is not msc Device"
Help please I don't really want to have to send it back to China??
Cheers
Johny
