CM10.1 for RK3188 is coming !! *closed*
    Hello all,
    The Time is come. CM10.1 (4.2.2) for Quad Core is coming.
    Right now it runs on my Test Hardware.
    Next I will try to enable Wifi and Bluetooth.
    More coming soon.
    *Update*
    Sorry Guys, I have made a Failure. It is not a CM10.1 Rom i Working on.
    But I will look to get CM10.1 in the Future to this Device.
    All I now can say Sorry.
    I will close this Thread now.
    Kind Regards
    Neomode
    Great man - great news...
      Which RK3188 devices will be supported?
        AW: CM10.1 for RK3188 is coming !!
        The most of them, it is running but no WiFi and Bluetooth. This must be ported to every new Device.
        Neomode Freaktab.com Developer
          Re: CM10.1 for RK3188 is coming !!
          If lan works, I can be a beta tester if you want. I have a MK802IV.
          Regards,
          Enviado desde mi LG-P970 usando Tapatalk 2
            Yes, no WiFi & BT needed, LAN rulezzz!
            Release Beta for entusiasts, w/o WiFi...
              If i remember correctly i've been trying some of Bob's ROMs and i already got one of them working without wifi BT on MK802 IV
              so... If you are that eager - you can try them out
                Thanks, I'll try ROMs from Bob.
                But CM is perhaps even more interesting?
                  from certain point of view - for me any working ROM is more interesting than the current one
                    This is really good news.
                    Is there any rk3188 stick that is preferable with regards to that it has hardware with open source drivers in it? There are slight variations on all the different kinds of sticks, just wondering which one is best to procure.
                    Signature? Signature!
                      o.k you want it you get it.
                      I release a beta firmware today.
                      the following is not working:
                      WiFi
                      Bluetooth
                      Adb over USB
                        WiFi
                        Bluetooth
                        Adb over USB
                        Overwriting modules with ones from working ROM would make them work, or are any more modifications required?
                        (wlan, bt etc...)
                          Right now I am working on that.
                          You need the Modules that´s right, also you must Modify the init.rc and init board in
                          Boot.img.
                          Neomode
                            I ported the wifi and bluetooth on the pipo rom for the t428.
                            You can find my work on experimental roms thread of T428
                            I'm interested in cyanogenmod. If you post your base rom i can help you.
                              This is a good Idea. I will be sharing my System and Boot Image with you.
                              I have tried enabling Wifi and Bluetooth but I must Work on.
                              Modification to Boot. image have I done and Copy the Files to the CM10.1 Rom.
                              As a Team we may can get success.
                              Neomode
