I can't really find any information on the internet i presume because it is a newer model or because it is a crap product.
T95 android tv box
T95 android tv box
Does anyone one know of a way to find out who made the stock firmware on a box. I want to try rooting my T95 and try to find a newer firmware that fixes the netflix and google play services issue with the model i have. The seller doesn't know who built the firmware.
Tags: None
there is firmware on yandex do not know the differens between them https://yadi.sk/d/kBDQgKXepu9wX/T95-1G
you can root the t95 with ezroot http://freaktab.com/forum/tv-player-...ez-un-root-zip
autoframerate in kodi fix is here http://forum.kodi.tv/showthread.php?tid=229310
youtube problem can be solved with ogyoutube search Google for ogmod
below not tested i have not netflix
netflix can be solved with exposed framework http://freaktab.com/forum/tv-player-...k-for-vega-s95
then instal netflix fix http://forum.xda-developers.com/atta...4&d=1378237913
No play in HD on OGYOUTUBE but I can download in HD with the T95 2GB ,
https://yadi.sk/d/kBDQgKXepu9wX/T95-1G this for T95 1gb no 2gb
Originally posted by Vid View PostNo play in HD on OGYOUTUBE but I can download in HD with the T95 2GB ,
what version youtube did you install framework version og the other ?
With ogyoutube10-45-53.apk the video play in HD but it freezes, it stops and resumes , and i tested this firmware http://chinagadgetsreviews.com/downl...-tv-box-2.html the same problem , google play doesn't work
Originally posted by poul50 View Postthere is firmware on yandex do not know the differens between them https://yadi.sk/d/kBDQgKXepu9wX/T95-1G
Has anyone had luck rooting and updating firmware on the t95?
Interestingly i recieved an OTA update on the T95 i have, suddenly netflix was working until i shutdown for the night and when it started back up was dead again. I'm really starting to hate this box worst purchase i made, my M8S which got bricked worked better then this thing. I'm leary about rooting to use xposed because the ezroot.zip makes no mention of working on this box and i don't need this thing to brick. If anyone has a suggestion on how to fix netflix not working then i would love some suggestions. to recap netflix launches, shows content, i pick somethign to play and it sits in an endless loading loop.
I bought one too. Compared to the S95 Vega I had, this one blows. So many problems...
Now if someone were to point me in the direction of an Openelec build for this, that may solve most of the issues, such as the audio glitching every once in a while for a moment, slow and fast playback, with no audio, etc etc....
There are currently 1818 users online. 2 members and 1816 guests.
