Which custom ROM is recommended for Beelink i68G?
Originally posted by tsukaza View PostSo far this combo works eliminating all the stuttering.
Modded ROM's for Tronsmart R68 "Tronsplant your ROM" V9 Rev2
My WiFi and Bluetooth fix
Beelink i68 firmware WiFi and Bluetooth fix for AP6330 chipset
http://freaktab.com/forum/tv-player-...ap6330-chipset
Thank you so much for your solution tsukaza. I works like a hell! I flashed the v9 Rev2 on my Beelink i68G (Gigabit ethernet) and then rename the file related to wifi and all works fine, and extremely easy because the rom included supersu preinstalled and esfileexplorer. SPDIF passthrough for audio 7.1 working as 5.1 as it should be on media center and after that on Kodi too. I think the built in player sets some stuff on the system that makes able Kodi to use passthrough, because the first time I tried on Kodi passthrough only worked for DTS and Dolby 5.1. I really apreciate your post.
Installed "TronZid-v9-FullROM.img" today (plus the Bluetooth Fix, did'nt bother with Wi-Fi yet) ... pretty pleased so far
After testing for about 4-5 Hours ...
1. Not a single "stutter" playing media from built in apps and Kodi
2. Dolby Digital and DTS 5.1 SPIDF Passthrough ... no problems, no noise
3. Auto FrameRate switching is working 50Hz / 60Hz / 24Hz
Thanks to all involved making the Beelink i86 actually "Usable" now !
I have the same problem ... the exact error message is
"Could'nt Sign in" ~ There was a problem communicating with Google servers --- Try again later.
1. My Date and Time are Correct
2. I am using a Wired Ethernet Connection
3. I am able to watch Youtube, use the Web Browser, look-up movie info in Kodi ... so the Beelinki86 has an Internet Connection.
4. Double Checked my Login and Password on my Smartphone and Tablet ... can connect to Google Play Store without a problem
5. Tried to Setup a New Google Account .. but results in the same "Could'nt Sigin in" Error
Update: i got the Wi-Fi working (can connect to the internet) using the fix/patch .... make's no difference !
can not sign-in to Google Play Store through the APP
but interestingly ... i "can" sign-in via the Android Web Browser
So i figured ... "the APP is out-of-date" so, grabbed the latest version (plus Google Services) of my Tablet (got the APK's using ES File Explorer Backup feature)
Updated the APP's rebooted ... and lost all Internet / Network Connection. No more Wi-Fi or Ethernet ... JEEZ
Anyways, un-installed (rolled back the updates) rebooted and got my Internet / Network back.
In closing ........
While i'm very happy with this Zidoo Firmware .... i'm a littled bummed i can download and install games and apps that i PAID for .... from the Google Store.
Any Ideas, Anyone ?
There are currently 2534 users online. 1 members and 2533 guests.
