Any suggestions for kernels to try? I'm supposed to use Jelly Bean kernels.
Successfully Running Lollipop on MK809III?
I tried loading Cyanogenmod 12.1 on my stick (RK3188, AP6210) which was made for CX-919, and it works! However, I can't get Netflix or bluetooth to work. The OP said bluetooth has a bug, so I thought I'd try different kernels. I'm guessing a proper kernel would make Netflix work as well? I don't know. The screen is mostly black with a distorted image across the top (there is still sound, though).
Any suggestions for kernels to try? I'm supposed to use Jelly Bean kernels.Android 5.1.1 for the CX-919 (CM12.1) This ROM needs first generation bootloader so follow instructions precisely. Bugs :- Bluetooth For smoother UI feelingTags: None
There are currently 4080 users online. 0 members and 4080 guests.
