Limited number of hard drives through USB??
    So here's what I have. It's the Tronsmart S95 Pro. My other box is an M8S. The M8S sees all my external USB drives just fine through a 7 port USB hub. The Tronsmart only seems to see 3 of my 4 drives. It doesn't matter how I plug it in or where. Either through the hub or directly to the unit. The M8S had no problem with this at all.
    2 drives are 2.5" USB 3.0 externals.
    2 drives are 3.5" HDD's in external enclosures.
    I can mix and match any three drives, but the fourth never shows up.
    Also, it won't read my 64gb SD card. It's a Patriot class 19 XC. Is it just the card type? Works fine with slower 32gb cards.
    Any ideas??
    Hmm.. might be time to buy a Network-Attached Storage (NAS) Device?
