Okay, so I have a new MKV which I programmed up last night and installed all the apps I want but today it wont boot. Hit the power button which stays blue for 12 seconds then switches back to standby. Decided to flash it with the Amlogic Burning tool to reset it and although the box is recognised and the update begins, it fails at 2% with the following error message:
[0x10105002]Romcode/Initialize DDR/Read initalize status/USB Control setup error
I've flashed other boxes in the past, Beelink X2's , MK808B's, MX-G's and MXV but I've never had that error message before. I would assume it's referring to problems with the RAM but any comments would be appreciated.
