mk808b with only 2.3 gb of space?
Originally posted by Droidocracy View PostPlugged up my mk808b to the pc, and it says I have a max of only 2.3 gig yet its supposed to be 8 gig is it not?? I'm running it stock, and just got it in yesterday.
/data 2.3G is good enough for app installation, more space for sdcard is better. IMHO.
Else you can flash Finless ROM with different parameter sizes to choose from.
I'm currently using 1G data size.
Originally posted by jtbc View PostThe remaining are used for your system files and sdcard (internal storage).
Re: mk808b with only 2.3 gb of space?
Originally posted by Droidocracy View PostIf I reset the stick to factory, and clear out everything it shows in storage 2.3g for apps unused, and 2.3g for internal nand unused. When I plug to my pc it only shows 2.3g usable. What happened to the other 2.3g? At the moment I put about 1gig of music, and can no longer download anything with it. 2.3 plus 2.3 equals 4.6g so where is the rest of the supposed 8gig?
Originally posted by Droidocracy View Posti know that. when i plug this to the pc shouldnt 2 windows pop open like with my tablets?
May be you can show us a screenshot of your settings>storage.
If your data is 2.3G, you should have around 4+G of storage space after minus off some space used up by system files.
Originally posted by Droidocracy View Posti know that. when i plug this to the pc shouldnt 2 windows pop open like with my tablets?Originally posted by jtbc View PostPC can't read some other type of formatted storage.
What kernel version and date is your mk808b?
Its look wrong. Your sure you have the original mk808b?
If i don't remember wrongly, my stock rom #28 13May2013(now already flashed to Finless 2.1) show about 1.5Gb for internal storage and about 4.3GB nand flash. The remaining of the 8gb are for system etc.
In Finless 2.1 , the total internal storage is 1.97GB and total Nand flash is 4.38gb if using the 2GB parameter file.
Originally posted by atac5922 View PostWhat kernel version and date is your mk808b?
Originally posted by Droidocracy View PostIt says I have almost 8 gig of space available split between internal space, and nand space. It will only allow me to use 2.3gig out of all of this. Seems kinda low to me as I doubt I need 5 gig for apps. Kernal is 3.08+ root@server #348 SMP PREEMPT Sat Apr 27 09:51:34 CST 2013. Build number is mk808b_402jl_17_01_2013.
I would suggest you reflash to Finless 2.1. Of course do a backup of your stock rom beforehand using CWM and make sure you have the mk808b original too.
internal storage=2.3gb unused
nand flash=2.3gb unused
installed music=1gb used
system+bloatware=2.4gb used, since you are on stock rom
so total=8gb
is that correct? Or like jtbc said previously take a screenshot of settings>storage and show it here.
so total=8gb
There are currently 3159 users online. 1 members and 3158 guests.
