https://mega.nz/#!as13wIZT!PIUWZutuy...-r8eo8VJAqMrko
Changelog (translated from chinese):
1. kodi update the latest official network (kodi-16.0-Jarvis-armeabi-v7a.apk), kodimate kodimate1.5 updated version;
2. The pre-kodi plug (Note: wire brush and sd card upgrade will upgrade preloaded kodi plug; ota upgrade is not preinstalled, does not destroy the original installation of the plug-in);
3. Optimize emmc erase mode, effectively avoid risks online upgrade failed;
4. Modify the APP installed, the interface displays the text color and background color when the button is selected;
5. Settings System sounds inside the selection of display issues;
6. Allow custom changes to the system partition 2G;
7. Address Start Card mode failed to brush machine problems;
Source:
SD UPGRADE: http://pan.baidu.com/s/1gfnTJoR Password:u0jb
How to install:
1. Download the firmware package and extract the contents (using an unzip app like 7zip, Winzip etc) to a micro-SD card.
You should end up with a micro-SD card containing 3 files, 'factory_update_param.aml', '/p200-ota-20160325.zip', 'recovery.img'.
2. Insert the micro-SD card into the MiniMX micro-SD port.
3. With the MiniMX power cable removed, use a paper clip or pen to press and hold the the pinhole restore button on the bottom of the MiniMX (on the base in one corner).
4. While keeping the restore button pressed, insert the power cable into the MiniMX.
5. Release the restore button when the MiniMX boots to an Android droid logo.
6. The firmware will begin to upgrade and will auto-reboot when finished.
