Official ROM Android 4.2.2
    My aliexpress seller (HENG XIANG HONG LIMITED) sent me this updated ROM for the UG007B :
    This is an Android 4.2.2 ROM
    Kernel 3.0.36+ hotack@adminroot-X9DRL-3F-iF #6 / Fri May 17 16:05:26 CST 2013
    build rk31sdk-eng 4.2.2 JDQ39 eng.hotack.20130517.172155 test-keys
    Antutu score :15381 (CPU 7745 / GPU 3985 / RAM 2794 / IO 857)
    Hope it could be useful for someone !
    Netflix
    Hi, Does Netflix work on this rom?
    I received today UG007 with 4.1.1 and Netflix work well. Not shure I want to upgrade.
      to root Official ROM Android 4.2.2
      download http://www.takilar.fr/UG007B_Root_Tool.zip
      based on VonDroid.com N101 II Root Tool based on work by sunnydavid
      if that can help
      I have test new rom , with 4.1.1 i had some trouble to connect to specific wifi router,
      with this version Wifi is OK on all my router
        Merci Takilar,
        Do you know if I can root my UG007B on 4.1.1 with the same tool?
          this tools was for an rk3066 stick , so you can try , the only risk is your stick don't get root
            My device also had 4.1.1 but the sound quality is freaking horrible! I've tried everything to fix it but can't, how is the sound quality on your device? If it's good would you be able to do a romdump of your device and upload it so I can try it on my UG007B?
              if that can help
              How did you install this rom over UG007b?
              Via Recovery? CWM recovery?
                If you mean the subject of this thread, I don't know xD. If you mean the root utility referenced in the post you quoted, it isn't a ROM, but a program that runs on windows and roots your device. Unzip it, plug your device into the USB and in "Settings->USB" check "Connect to Computer"; run AdbDriverInstaller.exe on the PC and it will show your device and say the driver is not installed or is installed improperly. You may need to run as administrator, and you may need to answer a dialogue from windows about something or other and tell it to continue regardless of whether it can verify it. When this is finished, run TPSparkyRoot.bat and follow the on-screen instructions (whenever it reboots the device, go into Settings on the device and recheck "Connect to Computer" before pressing a key and letting it continue). At the end of this process it will tell you it's done; reboot your device (root will appear to be installed but won't work until you reboot), and you will be rooted.
                  Installed this rom ( seems like what I had to start with ) but now no WIFI
                  I have an ap2610 chip, so I wonder if there might be a different stock for the device I have, which I believe is a UGoos UG007B. Any ideas where I could find this for newer wifi?
