Can't load apps on new MXQ Pro
I just bought an MXQ Pro and I'm having trouble loading apps. I went to systems and restrictions and set "unknown sources" "Verify apps" and "restricted profile" all to OFF. When I try to install the downloaded apps, I get the message "INSTALL BLOCKED FOR SECURITY MXQ IS SET TO BLOCK INSTALLATION OF APPS OBTAINED FROM UNKNOWN SOURCES" Any suggestions on what I can do to get my apps installed? The apps are not from the Play Store.Tags: None
There are currently 2851 users online. 1 members and 2850 guests.
