Tools and Instructions USB Burning Tools
Old Version new further down thread:
Temp Guide
http://blog.geekbuying.com/index.php/2016/02/20/android-tv-boxes-flash-tutorials-tool
Burning Tool
http://www.mediafire.com/download/58...ol_English.rar
Driver Assist V4.4
http://www.mediafire.com/download/8z...itant_v4.4.rar (works with 3229)
Tools from Radxa
Windows : http://dl.radxa.com/rock/tools/windows/
Linux: http://dl.radxa.com/rock/tools/linux/
Driver assistant v4.3
AndroidTool Release 2.35Last edited by trebor; 23 April 2018, 05:03.
Guest
Here are a few others from CGR:And they've also got some decent tutorials:
Guest
Also, this has a few more valuable tools:
http://www.mediafire.com/file/i1r66h649ga179b/root.zip- Android Tool v2.1 (allows backup and restore of individual partitions via USB OTG)
- RockChip AFTTool v1.62
- RKImageMaker v1.62
- MKUpdate.bat
Using this, I was able to successfully flash TWRP to the recovery partition, and from there you should be able to install the latest SuperSU flashable .zip file to root the device.
(Unfortunately, the included TWRP recovery had a bad fstab for my RK3328 device and so it couldn't mount any of the other partitions, but I'm much closer now.)
Androidtool v2.39 and Driver Assistant 4.5 now available.
Here
https://github.com/rockchip-linux/rkbin/tree/master/tools
And revamped versions with fixed English translations here
https://www.mediafire.com/folder/5qs985buhb8g5/Rockchip
Credit for the notifications and provision of the revamped versions to bernado, who's use of the tools to backup RK devices can also be be seen here.
http://freaktab.com/forum/development-area/rom-hacks-and-mods-development/10570-backing-up-your-rk-device-rom-with-the-new-rk-2-1-tool/page12R-TV BOX S10, Beebox N3150, Chuwi Hibox, Nvidia Shield, A95X Max
I've uploaded (FINAL) versions of RK Android Tool v2.3.9 (few fix for chinese and english texts in dialog boxes, chinese comments return in config.ini) and Rockchip Driver Assistant v4.5 (chinese comments return in config.ini).
I've discovered the commands can be used in a script file (*.sh) with the (new) Run function in Android Tool v2.3.9:
DB (?, seems not working in LOADER mode)
RD (Reset/Restart Device) [TESTED, it works!]
WL <BeginSec> <File> (download partition image at begin sector position, example: WL 0x4000 C:\rockdev\image\kernel.img) [TESTED, it works!]
WD (same function the WL command in MASKROM mode? accept same parameters?)
Rockchip device must be in LOADER mode to use these commands (I've only tested this with a tablet in MSC mode). You have to create a *.sh text file with one or more of these commands, by example:
Code:wl 0x2000 F:\Android\Image\misc.img rd
Code:wl 0x00006000 C:\Android\Image\misc.img wl 0x00010000 C:\Android\Image\kernel.img wl 0x00020000 C:\Android\Image\boot.img wl 0x00030000 C:\Android\Image\recovery.img rd
Hello,
I've an embedded systems based on a RK3288 which I try to backup by the Rockchip Andoid Tool last version v2.67, I was able to read ID and info, some img parts, but not all, I always receive Fail.
Log file joined. I tried with other version of software but exactly same behavior.
Any help would be welcomeYou may only view thumbnails in this gallery. This gallery has 4 photos.4 Photos
on the third Tab must be a Button to backup the hole .img ,
greetings / gefattern
Hi ,
Thanks for the helpYou may only view thumbnails in this gallery. This gallery has 1 photos.1 Photo
Originally posted by gefattern View PostHi ,
normal you only have to press "export image" , but i think this Function works not with
all AndroidTools , i know it works ,
good luck / gefattern
There are currently 1857 users online. 1 members and 1856 guests.
