Official X8-H PLUS 009 firmware
Originally posted by abdul_ptI don't have a X8, but if you are willing to do some testing i will make a rom for the X8
Sent from my Nexus 6 using Tapatalk
Edit : Also, I have tried to no avail to install your TWRP recovery. Can you cook it in the Rom?
I will use FW09 as base yes. It will include root also.
Yes, TWRP will be included. That's the first step-
Please try this recovery image. Placing it on the root of your ExternalSD and reboot while pressing the reset button should make it boot.
TWRP 2.8.7.0 - www.freak-tab.de/abdul_pt/aml..._X8-H_Plus.img
TWRP 3.0.0.2 - www.freak-tab.de/abdul_pt/aml/TWRP3_X8H_Plus.img
I formatted a 2 gig SD card as fat32 and copied the TWRP 3.0.0.2 to the root of the SD card. I got my Minix X8-H Plus into recovery mode by using a paper clip into the reset hole. The recovery did not "see" that img file at all.
I then downloaded the TWRP 2.8.7.0 and copied it to the SD card, and changed the name of the 3.0.0.2 to "update.img". Got into the recovery menu again, and it still did not "see" either of the two img's.MK818B, T428, ATV 1220, CS918S, TV01, S89H, R89, ADT-1, MK808B Plus, MINIX X8-H Plus, Tronsmart Orion R68
After you guys get over the recovery "problem", you can try to flash this zip
http://www.freak-tab.de/abdul_pt/aml..._Abdul_1.0.zipLast edited by abdul_pt; 01 June 2016, 01:43.
There are currently 2261 users online. 0 members and 2261 guests.
