Whats new in 3.0.0-0:[LIST][*]Completely new theme - Much more modern and much nicer looking (by z31s1g)[*]True Terminal Emulator - Includes arrow keys, tab and tab completion, etc. (by _that)[*]Language translation - It wont be perfect and especially some languages that require large font files like Chinese & Japanese wont be availble on most devices. Also some languages may only be partially translated at this time. Feel free to submit more translations to OmniROMs Gerrit. (mostly by Dees_Troy)[*]Flashing of sparse images - On select devices you will be able to flash some parts of factory images via the TWRP GUI (by HashBang173)[*]Adopted storage support for select devices - TWRP can now decrypt adopted storage partitions from Marshmallow[*]Reworked graphics to bring us more up to date with AOSP - includes support for adf and drm graphics (by Dees_Troy)[*]SuperSU prompt will no longer display if a Marshmallow ROM is installed[*]Update exfat, exfat fuse, dosfstools (by mdmower)[*]Update AOSP base to 6.0[*]A huge laundry list of other minor fixes and tweaks[/LIST]Whats new in 3.0.1-0:[LIST][*]support new CM 13.0 pattern encryption (sultanqasim)[*]fix slow flashing issue due to modprobe (present on only some devices) (#twrp)[*]libtar updated to latest upstream and fixes (jcadduono)[*]fixes for loading custom themes (_that)[*]TWRP will now detect and install TWRP themes automatically through the normal zip install process (Dees_Troy)[*]translation updates - added Italian, Czech and Polish and significant updates to Dutch[*]progress bar improvements - progress bar updates during image flashing and better tracks progress during file system backups (tar) (Dees_Troy)[*]fix input box text display (Dees_Troy)[*]reboot option after zip install complete (bigbiff)[*]other mostly invisible bug fixes and improvements[/LIST]Whats new in 3.0.2-0:[LIST][*]Fix a bug with the input box that affected masked inputs (passwords). This fixes decrypt of full device encryption on devices that support decrypt. This bug also impacts encrypted backups. Users are highly encouraged to stop using 3.0.1 if you use encrypted backups or if you need decrypt of data in TWRP.[*]Add Greek translation to some builds.[/LIST]
Here you will find the latest TeamWin Recovery Project for the Minix Neo U1. This is version 3.0.2-0 based on official source, the only adjustment i made was to make it backup the internalSD with Data, the only folders that it will skip are the TWRP and the Downloads.
I have built 2 images, one to use from External SDcard and other to use from nand.
From External SDcard
- Download the image, reaname it to 'recovery.img' and place it on the root of your FAT formatted external SDcard
- Power OFF the Neo U1 and power it ON while pressing the power button, keep it pressed for around 6 seconds
- Welcome to TWRP
From internal memory
- Follow the above procedure, but also place this image on the External SDcard
- On TWRP screen select install, click on botton right button (images), select storage and the previously downloaded image.
- Flash to recovery
- Enjoy TWRP
