Helping find stock firmware for M8S+
    I bought this TV BOX
    http://www.****.com/itm/201536557910...%3AMEBIDX%3AIT
    And I brick it by mistake.
    I tried to unbrick it with "usb burning tools" but I get a mistake "Romcode/Initialize DDR/Read initialize status/USB Control setup error"
    I think that I used not the exact firmware.
    Can you give me a link to the exact firmware ? (Or maybe it's not the problem)
    Thank you
    this is the exact firmware https://mega.nz/#!NcxQzAxZ!eiWD0Ic2H...KG944k_ipc.You must use the sd method.
      I already tried this firmware but it's not working for me.
      I think I need a firmware which update by usb.
        try this with usb burning method https://mega.nz/#!cJ1RnI4T!S2dq8VnOb...PrLKvm999qsxwY
          I tried it
          I have got error after 1%
          [0x10105002]Romcode/Initialize DDR/Read initialize status/USB Control setup error
            you must open your box and take photo of your board and post the photo here.
              you may have clone box.Try this rom for clone box https://www.copy.com/s/p3VXnfIDpMBijUnz
                and this rom https://drive.google.com/open?id=0By...EFkblRXRm5LWlE
                  Sorry for delay, I wasn't at home.
                  There is the photo of the board.
                  Hope it's help.
                    The pic too smalll
                    mega:///#!7kIU1RKQ!oC5Ed0aUweIf5xGjHVQhKgNPcUkdKvu3pbeBI9_ 6fCM
                      Originally posted by sufgi123 View Post
                      The pic too smalll
                      Hello,
                      This PCB looks exactly like dia's PCB from this thread: http://freaktab.com/forum/tv-player-...cked-m8s/page2
                      Step by step instructions by himself:
                      1. Download this u-boot https://mega.nz/#!nkYEyawZ!D8vrZgrFf...Rj9y9IqCU7qUbw
                      2. Download this firmware https://mega.nz/#!NcxQzAxZ!eiWD0Ic2H...NkZ_KG944k_ipc
                      3. Extract zip file and replace the u-boot.bin with the one from mega.nz
                      4. Format sd card with the u-boot.bin
                      5. Copy all files (factory_update_param.aml , M8S+-ota-20151216.zip, recovery.img and u-boot.bin) onto the sd card
                      6. Use the toothpick method
                      Greetings from Poland.
                        Originally posted by redliquid View Post
                        Hello,
                        Y E S
                        It's solve the problem, thank you all.
                        with this firmware the ethernet didn't work, so I install a newer firmware from the same thread and it fixed.
                          hey this worked for me to problem is after i turn box off with remote light goes blue and it wont turn back on ?
                            hello
                            i have tried different methods, sd card and burning tool, the only response is that burning tool connects and after 2% as result is says 0x10105002 Romcode/initialize DDR read initialize status/USB control
                            all red and stops.
                            any help ?
                            my box is m8s+
                            M9&m8_8bit_V1.1 2015/09/2
                            i tried almost every fw via sd card but it seems that only usb burning tool it gets recognized.
                            thanks
                            Last edited by kidjej; 09 August 2018, 14:28. Reason: motherboard information edit
