Leelbox MXQ 4.4.2
    Leelbox MXQ 4.4.2
    Hi I purchased one of these boxes and after the first reboot the wifi wouldn't turn on. I went into /data/misc/wifi and deleted the wpa_supplicant.config file that a lot of people say online to do and the file never replaced itself I am guessing it's because the box won't hook up to the internet. I noticed that my wifi mac address says unavailable and when I go into the wifi settings it has the wifi toggled off and when I try to turn it on it stays on "on" but it won't ever turn on. Any help would be greatly appreciated. Should I do a factory reset? Or do I have to flash something? Thanks for any help.
    Update**
    I did a factory reset and it still doesn't fix it. I did a nandroid from a similar box and restored system and data only to this box thinking it would fix it but still the wifi does not turn on. The ethernet connection works but not the wifi. I also checked on an android emulator and it doesn't show wlan0 or 1 or anything with wireless.
