Proud to provide shield tv owners with my guide to ouya anywhere without needing root
As described a way in which to load ouya anywhere leanback version on the nvidia shield android tv console,without root.I am sorry I did get lost a bit durin...
I figured this out,you will not require a rooted nvidia shield android tv,the controller for your shield works as a native ouya controller for this as well so no messing with setup,just install and launch the required apks and bang you have a shield android tv running ouya anywhere guys .
I am a modder,I only use previously made tools.So thanks to everyone who contributed the apks needed for this mod.
