I have a M8S+ with Android Lollipop. Since it only has 8GB I'd like to extend memory on this device with an USB disk or SDcard, However I can only use FAT32 which limits my file size to 4gb. If I use eXfat or NTFS i cannot write to these drives. It does not mount Ext4. I tried multiple tools to mount these disks but none seem to work. Does anyone has a solution for this problem or know a custom rom so I can use external storage for writing files.
Is there a way to get NTFS write access or EXT4 access on disk/sdcard mounts of the M8s+
Hello,
I have a M8S+ with Android Lollipop. Since it only has 8GB I'd like to extend memory on this device with an USB disk or SDcard, However I can only use FAT32 which limits my file size to 4gb. If I use eXfat or NTFS i cannot write to these drives. It does not mount Ext4. I tried multiple tools to mount these disks but none seem to work. Does anyone has a solution for this problem or know a custom rom so I can use external storage for writing files.Tags: None
There are currently 2396 users online. 2 members and 2394 guests.
