EWEAT M8V Amlogic S905 Android 5.1 Lollipop TV BOX KODI 1G/8G 2.4G/5G WIFI 1000M LAN Bluetooth
    Android 5.1 OS, rapid and stable, with a redesigned user interface built around a design language known as "Material design", avails the access to over 800,000 apps including Facebook, Youtube, Picasa and more.
    Amlogic S905, a high performing CPU running at 2,000.00 MHz Max., has 4 core(s) which results in extremely efficient multi-tasking in comparison with dual core processors.
    Penta-core ARM Mali-450, a separate graphics processor dedicated to accelerate the creation of images to be outputted to a display, is structured around processing large blocks of data in parallel.
    With support for 2.4Ghz and 5Ghz band, it can transmit higher amounts of data, and it’s naturally less congested.
    Gigabit LAN provides a data rate of 1 billion bits per second.
