Whoops... something went wrong
    Hey guys!
    I wanted to flash a new parameter and TWRP recovery and those went succesfull, but the system image failed. After a reboot I got a black (active) screen, but nothing else.
    Now I can't get it recognized by my pc so I can reflash it again. Sometimes it does get recognized as two separate storage devices but only in the device manager, not in the explorer.
    Holding down the power, the power and volume - doesn't do anything else then rebooting into the same active black screen. I do get to see a Pipo splash screen. Pushing the reset button doesn't do anything to change this.
    I am out of options and in need of help!
    What model?
    It may require that you plug into a power source first, then plug into pc to get to flash mode to restore it.
    If you want to change the parameter file, you need to flash all imgs at the same time, otherwise you will cause the sdcard space to overwrite part of the system space and lose the os.
    Currently Inactive on Freaktab.com
    I use: MK903V | MELE F10 Deluxe | Roku 3600R
    RIP: MK808b | MK809III | PIPO M9 Pro
      It's a Pipo P4. So I need to plug it into power AND pc?
        I know on my RK3188 Pipo you had to power it and plug it in to get it into flash mode if there was an OS problem. It may be a Pipo thing, carrying over to RK3288 devices. That is at least a suggestion to get you started.
          Yeh, thanks! I gave up after a while. I'll let the battery run out and try again.
          Really hard to do anything when I can't see what i am doing
            budgetgeek,
            I have a m9 pipo pro and the same thing happened. how do I make all flash at the same time. Thank you
              budgetgeek
              Eu tenho win10 e Windows Vista.
                Use RK Batch Tool 1.7 if single update.img. Use Rockchip 1.35 Tool for partitions.
